Burgerman wrote:You dont appear to be listening. This isnt your average forum. The people here, or at least some, are extremely knowlegable. Swap the plus and minus wires. Disconnect the inhibit pin. Problem solved.
Stop listening to your "experts"... Even the manufacturers. They are almost universally clueless. I am not in the least surprised they didnt see your problem. Stop over analysing it, esp as you dont understand batteries or electrics or charging! Just swap charge polarity and then come back here and tell us we were wrong.
This *is* the solution.
Alternatively if you really cant swap 2 wires, then just buy this, as it has already been done for you. https://www.discountscooters.co.uk/8ah- ... d-polarity
Added... If your battery has been left a long time in a less than fully charged state it will likely be less than good. Batteries must be stored in a fully charged condition. But if above about 9 or 10 volts each the charger will still charge them.
1 Amp will charge a 1000Ah battery. But will tale 1000 hours... Ideally you want an 8 to 12A charger.I guess another obvious thing to consider is whether my new 5A charger is sufficient to start charging these 75aH batteries.
Correct.I thought the only difference between my original 6A and this 5A charger would be the recharge time, but I don't know enough about the electronics of it all.
The charger cant tell. It just sees a voltage. If fully discharged a 5A charger takes 15 hours (5A x 15h = 75Ah) plus around 6 to 8 hours CV time. So a full day. Even if the chargers green light comes on sooner. Because it is still actually charging...I know these chargers get feedback from the batteries and charging won't kick in if voltage is too low (not an issue for me now). Is it possible that the charging won't start because the charger is reading the aH ratings of the batteries and it's not capable of charging them. Makes no sense to me.
What does the green connect to?
Green connects to pin 3.
Swap everything that goes to pins 1 and 2 to opposite sides.
Since I dont know how the inhibit is wired on that scooter then if it still does not charge then disconnect inhibit pin 3. But it should be fine judging by the 1st image.
Users browsing this forum: Mr.Math, shirley_hkg and 91 guests
