Burgerman wrote:You will find 4 wires... Connect all!
2 large. And 2 small for sensing voltage.
Burgerman wrote:any 50A anderson.
Burgerman wrote:Keep the cable you have. The two thin sensor wires allows the charger to correct for the charge cable. 6mm 2 is ok for the battery to the anderson connector on the chair. With a 50 to 100A fuse. If you want to be safe. I dont bother with fuse there but I am aware!
Burgerman wrote:At the battery plus.
Burgerman wrote:Old page.
http://www.wheelchairdriver.com/faster- ... arging.htm
Not sure if thats what you mean.
avonf55 wrote:Oh,and to test with a multimeter, do i just hold one prob on the terminal and the other on the frame of the chair?
Users browsing this forum: iainsherriff and 51 guests
