expresso wrote:i just tried 12A - charging - same thing - this time even sooner i got the error - i will leave it alone and not charge the chair tonight - will try it tomorrow evening -
Burgerman wrote:Itsuseful at times to be able to use a different voltage. Which is one reason I use the SM3040 bench supplies. I chose 1V or 1A up to 31V or 41A as needed. To charge, to test motors, when charging lead directly (just choose Amps, volts, connect! And so on).
If charging 24v its best to use 22 or 30V to avoid the issues you saw. Also a decent bench supply has a more stable voltage as its loaded. So helps avoid gettiung that problem to begin with.
Burgerman wrote:If you make one as a Y lead, (add another connection with a socket for your lester, to the 2 pins in the connector) you can use the PL8 once set to monitor. Charge with lester.
And graph what the old lester charger actually does. Which may be good, bad or probably terrible! Either way you will know then, and you can do the same with your other lead brick chargers.
Or buy on amazon.
Burgerman wrote:They may be wired with thin wires that wont like 12A. Usually used on microphones. So maybe better to buy one from a music shop in new york so you can see/ask what you are going to get. Or make it yourself just buy ends. You can also use it to top up a couple of chairs stored with one charger.
garriew wrote:Hows this cable working for you? Any pics of the complete one?
expresso wrote:garriew wrote:Hows this cable working for you? Any pics of the complete one?
if your referring to me - i never purchased this Y adapter - i forgot why i was interested in it already - haha - maybe to monitor a Charge on the PL 8 from a chair using dumb charger - i just made a XLR cable to use on the pl8 and stock chair with lead -
Burgerman wrote:You just need some of those SAFE 4mm connectors, some cable and an XLR plug, all from ebay. I have one here.
garriew wrote:expresso wrote:garriew wrote:Hows this cable working for you? Any pics of the complete one?
Didn't you make one to charge the factory batteries ? That's what I'm looking to do.
my new lead batteries are not getting fully charged to 100% with the preset and PL 8 - again today - i went out - 6 hours later its still at 330mAh now -
Users browsing this forum: No registered users and 97 guests
