I finally got to ride the chair with the new tire size 300-4 - chair looks nice - feels good over sidewalk cracks etc, - 10 PSI - i can manage it - i get the wheel shake at times - depends on surface - few other factors - - But making this change has changed how the chair handles feels - CG
Slam the caster hard and it should stop in a half turn or three quarters.
expresso wrote:My forks Castors are fine - they are tighten correctly - i changed all the bearings etc, there nothing else to be done to the castors - forks -
the reason i am having this issue is i changed my rear tires which were larger overall - it wasnt my objective to get larger tires - i just wanted black and wider on the same rim - going from stock 300-8 to 350-8 raised my rear up about 2 inches -
rustyjames wrote:Expresso, when you had the 300-4's mounted, what did you do so they wouldn't rub the footplates? That's assuming you're running the typical ones.
rustyjames wrote:@ Shirley, that adjustment is to change the dampening effect, won't change the height.
Burgerman wrote:Thers a large ring nut that sets preload, Large ring. Its threaded, and can be turned. Tightening towards the spring increases pre load and chairs height. Slackening it reduces preload and lowers chair.
Burgerman wrote:Unscrew it about 10 or 15 full turns. You "sit" on the spring. By unscrewing that nut, by maybe 1 inch you lose about 1 inch of height.
and turning the nut inward again ?
rustyjames wrote:I gave Shirley and others incorrect information. Yes, those shocks could be adjusted to increase the height, but I don't think you could gain anything more than 1" though because the motor housing doesn't have that much travel before bottoming out. To tell you the truth, I don't think the shocks on these chairs really do much at all to absorb any harshness, to me the ride is rigid with no suspension effect at all.
Burgerman wrote:and turning the nut inward again ?
What nut? A small one? Probably damping. Leave alone...
Users browsing this forum: LROBBINS and 102 guests
