by LROBBINS » 11 Dec 2019, 15:17
Having had a few days break from other projects I finally got around to putting together my second ZXD. Having re-cased one already, knowing what problems to expect, and intending to switch to low-noise thermostatically controlled fans in this one too, I figured it would go quickly. FLW. There were some significant differences between no. 1 and no. 2.
One problem in no. 1 was that the fine wires to the display screen had no strain relief and I broke one when re-mounting it at the top of the "fancy"case. In no.2 those wires were properly bundled and cable tied, but that bundle was so short that there was no way to make the screen reach the fancy-case cutout no matter how I tried to orient things. I had to unsolder, one by one in order to not mix up where they go, all but one of the wires and splice in an extension. While doing this I also noticed another difference: two of the wires (black and white) go to a small board added on top of the main boards. In no.1 this board was solidly affixed with resin, on no.2 it was held only by a single header pin connecting to ground - a failure waiting to happen.
Second difference. The encoder on no. 2 has a shorter shaft. Although the knob provided also had a shorter skirt, if fully seated the push function didn't work. Filing about a mm off the skirt was needed.
Third difference, though maybe in the fans rather than the power supply. When cold, these fans draw so little current that the power supply doesn't detect them. On no. 1 shunting the fans with 310 ohms (2 620 ohm in parallel because that's what I had on hand, 480 ohm was too much) took care of this. On no. 2 I hand wired in some SMD 330 ohm resisters - and the power supply didn't see the rear fan. Having lots of 120 ohm through-hole resistors, I swapped for one of these and we're back in business. Probably wasting near 60 mA at 12 V (ca 3.3 mA = 0.7 Watt at the mains) when at full speed compared to a resistor with a value just low enough to work - not worth worrying about.
Lastly, I did as ex-Gooserider did in his. I took the insulating sheets out of the stock case and put them into the fancy case (and re-did this in no. 1 as well). Probably not really needed though as for both of mine the coils are a good 20 mm or more away from the case, so the spark that bit Shirley was hardly likely to happen in mine.
So, in the end, it took me about as much time to do this second one as it did to do the first, but I now have two ZXD - one for my workbench, and one ready as a power supply for when I go lithium.
For those of you who bought units already in the fancy case, you may want to open them up and check a few things. See whether insulation is needed between the case and circuitry, see whether the wires to the display board need some strain relief (hot melt or some such would probably be enough) and see whether the little board mounted above the main boards is securely fixed in place.
Speaking of Li Shirley, what's happening with the possibility of having a capable top-only balance board? Any chance of getting whoever designed the ZXD modifications to add a function - so that if a top balance board sees that 1 or more cells go high it signals the ZXD to reduce output current? That would make it a real plug-and-play gentle and fast balancing solution for LiFePO4.
