Irving wrote:Shirley, are there any more available, modded if possible?
You mean you tap the Anderson shell , instead of using lock nuts ?
No room for nuts ?
Things got complicated then .
shirley_hkg wrote: Good new.
Fancy case with Anderson installed now.
I still need John's help to get it done.
steves1977uk wrote:
I'd buy one if you can get this done Shirley.
One thing you should be warned of , is the fan noise .
Thats what I did. BM removed the front fan completely in his to reduce noise I believe.
LROBBINS wrote:I did mine a little differently. My cutout is a little smaller so the "groove" in the Anderson fits into it. I then used just one screw from the side (don't remember if its 4 mm or 5 mm and Rachi's napping right now so I'm not going to check). It sits out a little further, but is securely locked in place even if the screw fell out. The Anderson plastic shell is actually soft and elastic enough that the machine screw can cut its own thread.
Hat's off to a great papa.
It is M4.
Burgerman wrote:No need for nuts. The M4 bolts tap the plastic easily and perfectly. Use nuts and washers if you want. When they come loose and fall inside you might regret that!
Good point .
shirley_hkg wrote:Irving wrote:Shirley, are there any more available, modded if possible?
YES .
1, In stock case @HKD $1,270
2, FItted with aluminium case @HKD $1,770
3, Fitted with aluminium case & Anderson SB50 @HKD $1,800
ALL are modified and shipping included .
Users browsing this forum: Bing [Bot], Jay_x and 45 guests
