shirley_hkg wrote: This may be my last offer of ZXD2400 in aluminum case.
Cosmetics not perfect. Dent on corners due to rough shipping.
I absorb the recent price increase , so selling with old price tag.
Let me know.
Price @$1,780 hkd.
shirley_hkg wrote:https://m.aliexpress.ru/item/4000385493813.html
Sulfuric acid contains sulfur, and hydrogen sulfide (H2S) is a possible by-product of over-charging and battery decomposition...........Overcharging, especially if the battery is old, heavily corroded or damaged can produce H2S. Deteriorated, old or damaged lead acid batteries should be removed from service, as damaged batteries are much more likely to be associated with production of H2S.
Burgerman wrote:May be. But a battery voltage of 16 displayed while charging at 12A says you are charging a 12V setup. Either in parallel or as individual batteries. That could end with a battery explosion. So turn it off and be sure you are both correctly wired, and then throw tham away!
Are they out of the chair?
YIKE!optical10 wrote:Here's the Diagram of my SB500's to ZXD2400.
woodygb wrote:The rotten egg odor is probably H2SSulfuric acid contains sulfur, and hydrogen sulfide (H2S) is a possible by-product of over-charging and battery decomposition...........Overcharging, especially if the battery is old, heavily corroded or damaged can produce H2S. Deteriorated, old or damaged lead acid batteries should be removed from service, as damaged batteries are much more likely to be associated with production of H2S.
woodygb wrote:YIKE!optical10 wrote:Here's the Diagram of my SB500's to ZXD2400.
You appear to be charging one battery only.
Users browsing this forum: No registered users and 330 guests
