ZXD2400 modification guild 3Kw 0-60V 0-50A
Postby Burgerman » 21 Jul 2019, 09:35
Almost. But I used a small dremmel cutting disk, a hand file, and a cordless drill for holes to do that. It took literally 20 mins. But I already had the case in bits as I was building the kit.
Postby shirley_hkg » 22 Jul 2019, 03:54
Learnt Will77 received his PSU's encoder bent. Want to impose better protection against DOA, with foam filler .
Would like to know if it is safe for electronics . czy :roll:
youtu.be/vyZenZeNjy0
Postby Burgerman » 22 Jul 2019, 04:11
Expanding polyurethane foam. Messy stuff. Sticks like really good glue, sets like that white hard polestyrene pakaging. And exapands like crazy.
Put some into a box, not too much, put the power supply in a plastic bag. And then into the box. And it will protect it totally. But it will be hard to get out. Mybe put soe goam into 7 or 8 smaller bags around the power supply may be better.
Postby Gnomatic » 22 Jul 2019, 04:28
Please don't put any of that into my psu. :fencing
Postby Burgerman » 22 Jul 2019, 04:43
He means in the box it comes in!
Postby Scooterman » 22 Jul 2019, 09:00
I’ve thought of spraying that stuff in the gaps between cells and battery box to stop them moving about? (If cell pack is smaller than group 24).
Postby terry2 » 22 Jul 2019, 10:18
Scooterman wrote:I’ve thought of spraying that stuff in the gaps between cells and battery box to stop them moving about? (If cell pack is smaller than group 24).
If you are going to do that.
Then put layers of clingfilm or plastic in there first.
Then fill that with foam. Reason? you can get it in and out with out problems :D
Postby Scooterman » 22 Jul 2019, 11:07
terry2 wrote:If you are going to do that.
Good point! :thumbup:
Postby Gnomatic » 22 Jul 2019, 16:01
Burgerman wrote:He means in the box it comes in!
Oh, I see! :oops:
I can see it being useful for packing. The box my last unit came in was all but destroyed. Fortunately the psu itself was unharmed.
Postby Scooterman » 22 Jul 2019, 17:27
Oh, I see! :oops:
Perhaps it was this delivery guy?
Another WD member uploaded this a while back in reply to one of my posts, it’s so funny :lol:
youtu.be/UOJiEgxt7RY
Postby Burgerman » 22 Jul 2019, 17:33
Postby ex-Gooserider » 23 Jul 2019, 02:22
The spray foam is reasonably safe for electronics as long as it is kept OFF of them by plastic bags, or sheets... If it gets on whatever you are packing it will all but NEVER come off...
(Make sure you protect anything in the area that you value, wear old trash-ready clothing, etc - be SURE to use eye-protection! For all intents and purposes, this stuff is 'forever' once it gets on something....)
The video claims a new 'reusable nozzle' but my past experience is that you should plan on using the entire can at one go.... It can be problematic to remove cured foam from the nozzle, and I have also often seen them stick on....
Some will say to use 'ESD-safe' anti-static bags, etc. but that is not a big issue on assembled products where the electronics are not exposed. If shipping boards or components then some sorts require ESD protection others don't... If not an expert the easiest rule is to use ESD protection if you can see the electronics... It will never heart to use it when not needed, but skipping it when needed is BAD...
Postby Gnomatic » 24 Jul 2019, 04:57
Scooterman wrote:
Oh, I see! :oops:
That was him! :thumbup:
Postby Scooterman » 27 Jul 2019, 13:20
LROBBINS wrote:I hadn't posted any pics of mine, but here's a sketch.
The side with the Anderson has the posts for mounting the circuit board.
But by mounting the as Anderson shown, did you not have to grind (or drill out), the tapped hole bottom LH corner of side wall alu plate?
Postby LROBBINS » 27 Jul 2019, 15:24
no
Postby Burgerman » 28 Jul 2019, 01:09
I am a bit baffled. Why are all you guys putting the anderson on the side with all the standoffs? I put mine on the plain side, there nothing in the way, no circuit board, no anything just space. :fencing
And why are all your power supplies built the opposite way around to mine? czy
Postby Gnomatic » 28 Jul 2019, 02:21
Here's how's my first one looks. Not as nice as others here. My Anderson cutout turned out looking great at first. But it was just a bit undersized. So we used a hand file to expand it a bit to fit the Anderson. So not as nice as anymore. But not terrible either.
Postby shirley_hkg » 04 Aug 2019, 13:31
Postby Irving » 04 Aug 2019, 14:12
Oooh.. Which one's mine? :D :D
Postby Burgerman » 04 Aug 2019, 16:09
2nd from the right. Unless they all get destroyed in the HK rioting. :shifty:
Theres 21KW output there. Or about 24KW input needed.
Postby AlexAGF » 04 Aug 2019, 16:29
Fine! Looking forward to sending.
AlexAGF
Postby ex-Gooserider » 06 Aug 2019, 04:36
Burgerman wrote:I am a bit baffled. Why are all you guys putting the anderson on the side with all the standoffs? I put mine on the plain side, there nothing in the way, no circuit board, no anything just space. :fencing
I am not certain as I haven't pulled mine apart to experiment and verify, but it appears that the supply can be assembled in several different ways if putting it in the fancy case, or rather the case can be assembled around the supply in different ways...
The two side panels are unique and will only bolt onto the heat-sinks and standoffs one way.... But the holes for the top and bottom are the same, so it is not at all obvious which end goes up when bolting them on....
The end plates and fan can also bolt on with either end up, although it is pretty obvious which way they need to go in order to match the handle and feet....
So the 'guts' of the supply can end up in the fancy case with either the same orientation as they did in the factory case, OR 'upside down'....
It shouldn't make any difference in how the unit operates, though I would be inclined to keep the orientation the same as factory in case there is some non-obvious subtlety like how the parts are supported....
However if keeping the factory orientation, then the wire bundle from the control board needs to be routed off the board on the opposite side than how the directions for installing the mod kit in the OEM case specify.
The other big difference that results is which side of the unit has the supports and such. It sounds to me like this is why some people are having problems adding the SB-50 in the back and others aren't....
Postby shirley_hkg » 10 Aug 2019, 13:27
Makes me wanna get one for myself too. cheers drunk2
Postby Scooterman » 10 Aug 2019, 13:39
Very professional Shirley :thumbup: :thumbup: :thumbup:
Postby Gnomatic » 11 Aug 2019, 01:44
Looking good! :clap:
Postby shirley_hkg » 13 Aug 2019, 05:07
PSUs will soon board their 48---58 day slow boats .
Should anyone prefer a jet plane to the unbearable slowboat, please let me know .
Postby Burgerman » 13 Aug 2019, 08:45
But on the news your airport is all full of tear gas and demonstrators. And shut!
Is this all overblown by the media as per usual?
Postby shirley_hkg » 13 Aug 2019, 09:13
Quite a number of flights are cancelled , since yesterday afternoon.
No violence , no tear gas, yet . drunk2 cheers
Postby Burgerman » 13 Aug 2019, 09:15
I hope china doesent ruin HK.
Postby shirley_hkg » 13 Aug 2019, 09:38
The die is cast. Any shaking of the communist regime is forbidden.
Hope it doesn't end with bloodshed.
Users browsing this forum: CPguy, duke1, Google [Bot], hank, ICEUK, peterik and 23 guests
