woodygb wrote:The inhibit is usually a connection between GND/Battery negative and the center pin of the charger socket.
The inhibit link is inside the charge plug....see pic.... BUT any similar connection somewhere in the wiring could also cause this fault.
NOTE:- Pin 3 will be connected to the main controller via the wiring.
Burgerman wrote:And the inhibit for either on board or external charge is reversed. In programming.
woodygb wrote:I did ...yesterday ...look for an onboard charging option for the Quantum 6000Z and couldn't see one listed.
https://www.southwestmedical.com/replac ... r-assembly
woodygb wrote:Perhaps try pulling the inhibit high, by connecting the positive to the inhibit via a 10k resistor.
firehopper wrote:woodygb wrote:Perhaps try pulling the inhibit high, by connecting the positive to the inhibit via a 10k resistor.
I can try, I'll have to dig through my pile of parts and find a 10K resistor.. I have some in my parts box I think
Burgerman wrote:If you disable the inhibit, or reverse its parameters in software it may be fine. Or you may need a new joystick pod...
Try a 5k resistor...
Burgerman wrote:If that works then the charge inhibit is configured in reverse, as it would be if you had an on board charger. Which means either:
J/S pod is faulty.
Someone has replaced the power module and it has on board charging connected previously.
Someone has been messing with the programming for reasons unknown.
In case the code triggered is incorect, test the freewheel lever. It disconnects the brake, gives a similar error. Engage and disengage many times, check microswitches. Also test any seating microswitch inhibits such as tilt... Similar error, may be misconnected to wrong inhibit.
Users browsing this forum: Burgerman, DrewDigital and 131 guests
