vinsen wrote:good afternoon. I can not connect the controller. gives an error message .
http://support.pgdt.com/Online-Diagnost ... Codes.aspx
what control do I need on this controller? I tested the gas pedal with a hall sensor. power 4-5 volts. I tested a resistor of 100 KOm. Does not work . I mapped the type of potentiometer 0-3 . Does not work ......
https://youtu.be/MWyq7KLMYMY
A throttle trip is indicated. Make sure that the throttle is in the neutral position before switching on the scooter.
woodygb wrote:A spring makes the potentiometer return to center on the Wig Wag throttle
woodygb wrote:0E08 Throttle Wiper Error
This occurs when the controller detects an error with the Throttle Wiper. The Throttle Wiper input is located on pin 1 of
the 14-way Tiller Connector. Check the throttle potentiometer, programming, connectors and relevant wiring to the
controller.
If the trip is still present after the potentiometer, programming, connectors and wiring have been checked, the controller
may be defective. Refer to Servicing Of Defective Units.
note:- You MUST have the potentiometer set @ 2.5v WHEN you turn the controller ON.
Users browsing this forum: shirley_hkg and 86 guests
