snaker wrote:These 100AH cells seem too big. The cells below have better sizes which can fit 16 in a powerchair.
80AH ALT cell
http://lifepo4.vn/product/pin-atl-3-2v80ah-moi/
80AH Coslight cell (86AH claimed)
http://lifepo4.vn/product/pin-lithium-s ... u-xe-dien/
90AH EVE cell (92AH claimed)
http://lifepo4.vn/product/pin-eve-lf-3- ... le-dod-80/
They are all showed on taobao. The prices are just a little higher than taobao. Maybe the seller imported them by huge load. They also offer building packs (with BMS) for free.
steves1977uk wrote:@Shirley, are there any 75Ah+ (10C) cells with the following dimensions...
Height 170mm
Length 197mm
Width 40mm max
Those 90Ah cell would fit perfectly if they were 30mm shorter height wise!
Gnomatic wrote:These Sinopoly's are interesting. Would be a lot simpler to convert a chair to lithium with eight of these vs. assembling dozens of Headway cells into a pack ect.
Who's going to be the guinea pig?
hobie1dog wrote:Is there a way to subscribe to a thread and get email notifications everytime a post is made?
shirley_hkg wrote:steves1977uk wrote:@Shirley, are there any 75Ah+ (10C) cells with the following dimensions...
Height 170mm
Length 197mm
Width 40mm max
I think so .
Its been quite some time now , since I spotted it , and the better ones usually went first .
I might get 16 LF90 , because I know the seller well . He shall response if the batteries have problems .
shirley_hkg wrote: Dimensions of your battery space
hobie1dog wrote:Yep, checked the box- Notify me when a reply is posted.
Burgerman wrote:True. And not even a BMS fitted. So it is not going to last long!
Also, https://www.jypwr.com/shop/lithium-agm- ... /ft825-34/
Is a PC1500 Odyssey in disguise with a bit of fancy marketing. Thats the same as the old Die-hard one. Its got the Odyssey 2.5mOhm, and other specs, and so its internals. They like their wizzy marketing these ICE fans!
Lithium likes it in the middle, where its got 30 to 70% charge, and where all charge and discharge currents are low. Then they last for decades and dont deteriorate noticibly. But at the same time you do have to use them! Its all about understanding this, and using them and planning accordingly.
Burgerman wrote:Tru. But 8 of these will/should fit as 2 rows of 4. http://www.lifepo4-batteries.com/sale-1 ... f-car.html
That will give roughly 4.4 times the range of an MK at the 5 hour rate. So if your chair claims 30 miles, as mine does, you will get 132 miles with these...
Burgerman wrote:How much doesent it fit by?
The grp24 spec says 173 x 260 x all kinds of heights up to 240.
Users browsing this forum: acid_coke, Bing [Bot], daveonwheels, woodygb and 114 guests
