Burgerman wrote:You dont want a bare one. You want good quality 4s ones that have a plug and socket. You cut the cable in half, and the plug goes on the battery. The socket goes on your chair side SUB-D connector...
Quality ones can be bought from Revolectrix / cellpro. You likely already have some 36 inch 8S ones. And you could use these. But they sell 4S too to make it simple. http://www.store.revolectrix.com/Produc ... sion-Cable
Gnomatic wrote:These Sinopoly's are interesting. Would be a lot simpler to convert a chair to lithium with eight of these vs. assembling dozens of Headway cells into a pack ect.
Who's going to be the guinea pig?
Burgerman wrote:Cut 4 wires off one, and then look at it again!
shirley_hkg wrote:snaker wrote:My maddest range: 83km/89.5 returned Ah.
I think you've created a GUINNESS WORLD RECORD already .
Truely , 83km in less than 6 hours for a wheelchair is hard to break .
would you use the same preset that was used for charging ONE headway 15ah cell ? and just up the charge rate ? since these are 100ah each -
can use 15 or 20A charge rate ? that would take about 4 hours easy if not fully drained - 24 hours for 8 Cells - then build it - test it - discharge - recharge and install - you would get it done in a few days -
shirley_hkg wrote:AND has created a GUINNESS RECORD shortly after his battery installed .
viewtopic.php?f=2&t=1813&start=3160shirley_hkg wrote:snaker wrote:My maddest range: 83km/89.5 returned Ah.
Burgerman wrote:would you use the same preset that was used for charging ONE headway 15ah cell ? and just up the charge rate ? since these are 100ah each -
Make a copy of your 90Ah chair profile. Rename to LiFePO4 1S 100Ah. Then just change the 8S to 1S in the first tab... And save.
Or use the single cell one and increase charge Amps, and set termination current to the same as your 90Ah pack.
Where do you see that - First Tab - Change 8S to 1S ?
Burgerman wrote:Where do you see that - First Tab - Change 8S to 1S ?
Under detection>cells> set to 1. But it may insist on a cell balance connection! Stupid profiles.
So you may be better to adjust Amps and termination mA in the single cell profile I did already as that wont need a cell voltage balance connection. So its simpler..
Under detection>cells> set to 1. But it may still insist on a cell balance connection! Stupid profiles.
garriew wrote:Has anyone actually used these before? It's a lot of money to spend for crap batteries.
snaker wrote:My time is 05:00 wake up, 07:30 go out, 15:00 get back home.
I am driving people in my family mad. They do not like that I go alone in long time
LROBBINS wrote:Expresso, If Snaker's schedule seems awful early to you, do remember that Vietnam is a tropical country and it gets exceedingly hot in the afternoon.
Users browsing this forum: No registered users and 60 guests
