Sinopoly Cells - Info -
Re: Sinopoly Cells - Info -
Postby Burgerman » 25 Apr 2018, 02:33
How old?
New or used?
How much for 16 with shipping? :worship
Still think these are better. download/file.php?id=8172&mode=view
Postby shirley_hkg » 25 Apr 2018, 02:59
Claimed to be new old stock .
Shipping rate as mentioned previously .
Those are gone .
User's review below , has lower IR than that of the 170Ah ones .
Postby Gnomatic » 25 Apr 2018, 03:05
What are your thoughts on these, shirley?
https://item.taobao.com/item.htm?id=540 ... oSite=main
Postby shirley_hkg » 25 Apr 2018, 03:22
Will work.
IR is higher than mine , and you can't fit 16 of them . Only 2 reviews so far .
Enough room to fit a 2P9S pack into a G24 space . Any good ? cheers drunk2 :dance
Postby Burgerman » 25 Apr 2018, 10:35
2P9S
Postby shirley_hkg » 25 Apr 2018, 11:46
Higher volt . drunk2
Postby Gnomatic » 27 Apr 2018, 02:15
Well, I'd like 16 of those cells or similar, but want to first find a metal box I can fit them in.(after box has been insulated) I can make fit.
Postby expresso » 27 Apr 2018, 02:33
i may also be interested in those cells or similar which have to fit in a group 24 size battery box with no modifications - that would give me 150ah ?
how would the connectors work - do they sell connectors etc, screws everything thats needed ?
As long as they fit in a group 24 battery box - i cant do modifications to that battery box area -
thanks -
Quickie P222se - 60Ah ADD ON
Quickie P220 - Indoor Chair
Bounder Plus - 180Ah LifePo4
Postby shirley_hkg » 27 Apr 2018, 02:39
Gnomatic wrote:Well, I'd like 16 of those cells or similar, but want to first find a metal box I can fit them in.(after box has been insulated) I can make fit.
We always have tailor-made SS boxes.
Its easy to get things done here.
https://www.wheelchairdriver.com/board/ ... 66#p118266
Postby snaker » 27 Apr 2018, 02:47
It's hard to find a built-in box that fits our needs. The easiest way is asking a local shop who sells inox sheets (rolls?) do it for you. Mine is 1.5mm thick and costs $20 (material and labor). 1.5mm is already very sturdy and bulletproof :ak47
Postby expresso » 30 Apr 2018, 23:30
https://www.aliexpress.com/item/8Pcs-Lo ... autifyAB=0
seems to be very similar to the sinopoly - just less expensive - with free shipping - wonder if they are all the same just different brand
Postby Gnomatic » 30 Apr 2018, 23:50
They do look similar.
Postby Gnomatic » 01 May 2018, 17:39
Their specs are identical to Sinopoly.
Also, if you want to see how Sinopoly's hold up in sub-optimal conditions .......
youtu.be/aQs7L5LmEss
Postby Burgerman » 01 May 2018, 18:57
Well thats EXACTLY how I treat my battery every day. So thanks for that!
Seriously, its well known that unlike Laptop / tesla style LiCo, or LiPo hobby type batteries, which burn and explode, ours just dont.
LiFePO4 we use will only burn if you can heat them up with additional external heating like a flame, adequately enough to boil the oily electrolyte out of the cell. And give a source of ignition. Much like hot cooking oil. Thats actually safer than lead which produces hydrogen and oxygen and can blow up violently while spitting sulfuric acid in your face. Although the smoke smells pretty bad. Thats why we are using them. Before committing myself to them I made damned sure!
I have however accidentally had lipo batteries explode or flare up violently in hobby stuff for no apparent reason. Several times. Other than what seems like normal use. Dont trust those things one bit! There are just 2 in my house where I can see them. The rest are in an old fridge in my garage. And at my flying field we destroy old ones in a ritual with a nail before going home for fun. :clap
Postby Dan » 01 May 2018, 20:31
£1,213.90 for two, is anyone tempted? I will have to check to see if two will fit a Storm 4.
Dan
Postby Burgerman » 02 May 2018, 00:07
How did you get that price? :fencing
£618 delivered for eight. And thats all you need.
The price of lithium continues to fall.
Thats for 100Ah. More than 2x the Ah you get from a pair of MK batteries, Which will only allow about half the 73Ah. Say 40 to 45Ah to be used at the high rates we use them. So price per usable Ah is already much less Because realistically thats the same as buying four MKs for range. That would cost £850!
And its better yet again, since these will last around 2000 cycles, or much better, instead of 500 at very best. Because if you only use the same range most days as before, they will give around 5000+ cycles, as you will only need to replace under 50 percent. Thats 10x more cycles. Or allow a charge every 2 or 3 days in winter.
Postby Dan » 02 May 2018, 00:53
Can't see how I missed its 8 for £618 czy
Battery Dimension:221*142*61(+/-1mm)
Would that be at least 22.1cm tall 28.5cm wide 24.5 deep for both side by side.
Dan
Postby Burgerman » 02 May 2018, 02:26
Yep. Be sure you have the height you need.
Postby Gnomatic » 02 May 2018, 02:35
Burgerman wrote:Well thats EXACTLY how I treat my battery every day. So thanks for that!
I thought that vid made a strong case for LiFePO4 given the torture. You can look up youtube videos on lead acid batteries being abused and see more smoke fire etc. Which is a point you've been making for many years.
Postby Burgerman » 02 May 2018, 10:25
Yes, it does. I was joking! I actually sawed a fully charged headway in half. Some smoke. Still worked.
Postby terry2 » 02 May 2018, 16:29
Burgerman wrote:How did you get that price? :fencing
Would you need a special charger for these and would they(8) take up more room then 2 MK batteries?
Postby Burgerman » 02 May 2018, 21:09
They may be a tiny bit taller. But otherwise they will fit. You will need a pl8.
Postby expresso » 02 May 2018, 21:13
Burgerman wrote:They may be a tiny bit taller. But otherwise they will fit. You will need a pl8.
oh really - i though they were shorter than a MK Gel battery ?
Postby Burgerman » 02 May 2018, 21:20
lithium cell is 221*142*61
MK is
Dimensions(mm): 260Long 171Wide 210High
Terminal: FEMALE 1/4"
so add some for terminal connections on both battteries.
Postby expresso » 02 May 2018, 21:27
i show 235mm for MK with posts on top - which is what is used in my chairs so this would be shorter if all numbers correct - MK spec sheet i have show 235 high
Postby Burgerman » 02 May 2018, 21:34
Theres a few terminal variations on MKs. In some chairs they specify the FT version (flat top, femake threaded connection) due to height restriction. On others, they have the type you had.
Common type, MK 74Ah FT gel:
Non FT version usually not supplied for powerchairs but solar/marine etc. Same exact battery otherwise. Although this is a 50Ah one:
Postby Burgerman » 02 May 2018, 21:45
These are EXACTLY the same internally/elecrtrically, 74Ah MK gel, sold as marine/RV batteries. Also fitted to chairs and used for solar. Marine terminals.
Postby expresso » 02 May 2018, 21:48
yes i figured that - mines were always with the Posts up high - not flat top so i am going with those specs - which means these are shorter - makes it a sure fit for me -
i am thinking of my new chair - which they may come with flat tops - i am not sure till i get it and check - all my other chairs all had posts on top like marine style etc,
so it should fit fine - thats why everyone has to check there battery space and cant compare from others -
Postby terry2 » 03 May 2018, 11:42
So I would need a charger for the PL8 and then these. So about £1,000 all told. Will wiring them up be easy?(for me that is)
Postby Dan » 03 May 2018, 13:44
terry2 wrote:So I would need a charger for the PL8 and then these. So about £1,000 all told. Will wiring them up be easy?(for me that is)
You would need a PL8 and a power supply for the PL8. I would also very strongly advise you to measure the battery box in the wheelchair your going to use. You may also spend about £100 on cables, tools and bits and pieces.
I think they will be easier to wire up than loads of individual cells but you will have a bit of work to do and you will need to gain some knowledge and understanding.
Dan
Users browsing this forum: Chikinhed, Google [Bot] and 29 guests
