I finally got a quote on the new big screen R-net controller... $900 Canadian, USA dealer is $600USD
Burgerman wrote:I finally got a quote on the new big screen R-net controller... $900 Canadian, USA dealer is $600USD
They are 1/3rd that brand new from PG Drives here in the UK.
Burgerman wrote:Yep.
Pride has in the past had various types of controllers from a few different manufacturers. They often have the renamed or rebranded as thier own. Eg they used pilot plus, for eg but called i something else with a new moulded joystick housing. Then theystarted calling the curtis instrements enable 50 system qlogic... But at that time the curtis rogrammer still worked fine. Dealer and OEM. Then they moved to qlogic2 and it was more difficult and they used modified firmware and some would connect but not all features were the same. Now they did it again with qlogic 3 made by curtis but nobody can program it except dealer at dealer level and the OEM level tools are aparently non existant. In fact they do exist but only pride have them under lock and key. So run away if anyone suggests a pride chair.
Burgerman wrote:Its really a Curtis instruments programmer and controller, rebranded for pride who dont make controllers but love us to think they do. The curtis software is available and it MAY connect. Some say it does. Others say no. Depends on versions I think. The cable you have to make.
No luck connecting to OEM. Sigh. Oh well was worth a shot. I can see the OEM option but it just won’t connect. The older version won’t connect at all. (USB CAN Adapter: Unable to reset USB adapter”
woodygb wrote:
http://www.nocoev.com/curtis/Software%201314-4401/
You will need to buy a Chinese A1 CAN - USB adapter and alter / add some files to make CAN BUS work.... assuming that your controller is CAN-BUS .
The latest Curtis software is available plus a hack for the registry.
FelipeOliveira wrote:good afternoon. could someone tell me what it means, and what should i do? the Tilt function does not work
woodygb wrote:FelipeOliveira wrote:good afternoon. could someone tell me what it means, and what should i do? the Tilt function does not work
Indr_Avg = INDOOR
https://www.invacare.com/doc_files/1141471.pdf Page 40
Page 79 Powered Seating Menu
DLO ( DRIVE LOCKOUT )
Users browsing this forum: acid_coke, Burgerman, Jay_x, martin007, mentado020477, woodygb and 99 guests
