Burgerman wrote:Housework, sweeping up, turning left right, grass, gardens, slopes, hills, all use easily 10x more power than driving in straight lines, so its possible to do what you said you did.
Turning left, at zero speed, uses 100A per motor to turn. Every time you do it.
Driving at max speed uses maybe 10A or 15A or so.
Driving up a hill, anything up to 100A or greater..
Grass? Doubles everything.
Solid tyres, add a few amps.
Tired less efficient motors, maybe adds 10% wasted energy
Nose heavy chair, eats power on turns.
I can kill a set of lead batteries leaf blowing the crap off my drive and garden. In say 1 hour. And get roll back and no power3 or 4 times over!
Same chair will go 3 hours at 6 mph non stop and do 18 miles. In a straight line. But not if I waste a load of power getting ready in a morning around the house. That halves it.
snaker wrote:@hotwheels_75: Can you fit a camera and record your off-road in a couple of km? I am really tempted to see the way you drain 10Ah/1km
A 4-digit voltmeter is easy but good and safe enough, fit it before your next 'draining test'.
Burgerman wrote:There are usually these options:
4mph HD with 4 pole. For high torque bariatric use.
4mph 2 pole because its cheap slow gives adequate torque.
6mph 2 pole because its cheap! And useless...
6mph 4 pole because it works properly, and can make use of a bigger amp controller.
8mph 4 pole - same as above, but less torque and control, high drain, more speed, otherwise the same as above. OK on flat ground, and are skinny...
Users browsing this forum: LROBBINS and 71 guests
