hobie1dog wrote:While we are talking 636 wheels and tires, my same stock setup measures 25 3/4" wide. I would love to get a tubeless tire that would be slightly taller and wider. I like the look of the 120/70 tires that were pictured. Are there wider wheels with more offset, which can be bolted to the stock hubs? I don't mind adding extra width to the chair.
Burgerman wrote:None I ever found. However if you cant make an adapter, shirley_hkg can do it aparently.
Burgerman wrote:The turf tyres I use will fit.
expresso wrote: -
i recall shirley added the rims to his chair etc, but it didnt add any width over the 3.50 x 8 tire he was using before ? i think he went to 10 inch rims - but seems the same width from some pictures i seen a while back
shirley_hkg wrote:expresso wrote: -
Want to see my chair again ?
viewtopic.php?f=2&t=5380&p=82283&hilit=shirley_hkg+tubeless#p82283
expresso wrote:As it the tire rim sits right now on my chair - its as close as it can be to the motors - i mean its so close that i didnt think it would work but it does - the tires can not go in closer the motor any more.
If i understand you correctly BM - does this mean that if i used the rims from shirley with a hub adapter he may make for me - and use the same 3.50 x 8 tire on a 2.5 rim - this would make my chair even wider than it is right now at 26.5 inches ?
Burgerman wrote:90.5mm pcd. 4 bolt. 75mm centre hole.
g
