Burgerman wrote:For a bunch of reasons you need to replace 75Ah lead with MORE Ah than you remove.
To not do so means you will miss out on the improved energy density that lithium allows. Which is the whole point. And will not take advantage of the increased lifespan possible. Lithium hated high discharge rates, and being full, or empty. So a large pack means you charge less frequently, and work each cell less hard.
For EG one of my chairs uses 120Ah lithium, the new chair I just aquired will be getting 180Ah. The smallest pack that makes any sense is about 90Ah as used by expresso in new york.
shirley_hkg wrote:It seems you are using Ackerman steering , instead of differential steering .
Why not use differential axles ? They have high/low gears too .
Around US$ 90 --- 200 .
Can be very short wheelbase.
shirley_hkg wrote: They are all over " taobao " .
1500W motor plus rear axle completed with high/low gear shift is US $120.00 , and others lowest as $60.00.
grazy+1949 wrote:shirley_hkg wrote: They are all over " taobao " .
Hi Shirley,
As I don't speak Chinese. Can I change the https://world.taobao.com/ to English display?
Please can you give me the URL of the page you are quoting from?
thanks , graham
grazy+1949 wrote:shirley_hkg wrote:It seems you are using Ackerman steering , instead of differential steering .
Hi, Shirley I just love the whole set up of the differential axle. Can you please give me more info on prices and where I could source 1 for my next project
Burgerman wrote:Because to us westerners the site is all hiroglyfics... (I know I cant spell) And as understandable as an egyption pyramid. And theres no ENGLISH button!
There are already a few off road chairs
Users browsing this forum: shirley_hkg, tettralytic and 61 guests
