about 3800 miles on the chair
I replace mine every 2 years as amatter of course
Burgerman wrote:Motor wear, has nothing to do with distance.
It has to do with CURRENT! Amps. Heat. If you program your chairs like I do, they fail fast. Since it makes the chair jump when told! If you program it to actually respond and then USE it hard, they take 100A at every turn, every hard acceleration, every wheelie, and so on. If you do a few hundred miles like that they will break! Likewise, if you are heavy, live on a hill, they will soon fail due to heat soak, and Amps burning brushes, making motor couplings/ cush drive rubbers fail, and gears wear fast. And the all important magnets become weaker. You lose efficiency and torque.
The opposite is true. Used lightly Stock mushy programming, lightweight user, mostly in straight lines, few hills, less indoor use (which eats motors faster) and your motors may last easily 10x longer.
and some repaired by me
The motors of my powerchair are 19 years old.
I only change the brushes.
* I live on a plateau and I am thin.
expresso wrote:how can i know for sure they are correct speed ? also thats in the UK - not sure if they will ship it to me and the cost -
i will ask though anyway -
but i need to be sure of the speed -
shirley_hkg wrote: May be brake is dragging , so you hardly started .
Burgerman wrote:Clear the errors, drive the chair, check again. If the motor open circuit error happens, only, then you have a brush problem.
elryko1992 wrote:expresso wrote:how can i know for sure they are correct speed ? also thats in the UK - not sure if they will ship it to me and the cost -
To see the correct speed look to RPM: 163 is 10KM, for 8.5 MPH i don't know maybe more than 200 RPM
elryko1992 wrote:Its not worth to buy from UK the ship is very expensive to USA because is heavy motors 18-20KG, check on USA ebay is more motors for you.
https://m.ebay.com/itm/Quickie-Pulse-6- ... SwL6tanZNP
And
https://m.ebay.com/itm/QUICKIE-QM-710-P ... SwTodbJ-x9
Users browsing this forum: martin007, Raro, woodygb and 101 guests
