by Burgerman » 25 Jun 2018, 09:38
Turn acceleration means that you move the joystick or whatever input you use, left (or right) and the chair does not move straight away but slowly accelerates to the turn speed. This feels like delayed steering action. At the max speed setting.
Minimum Turn acceleration means that you move the joystick or whatever input you use, left (or right) and the chair does not move straight away but slowly accelerates to the turn speed. This feels like delayed steering action. At the max speed setting. At the slow speed settings. Or at small stick movements.
The two settings above determine how fast the turn is innitiated. You choose. But setting these high to 70 or more is quite important unless you want it sluggish and delayed.
But more importantly...
Turn deceleration means that the turn that you are already doing, continues long after you tell it not to! And this is always set at a slow rate. so you hit door frames or drive off the pavement! This must be set high. Mine is sat to 100. Which effectively means it stops turning the instant you say so.
Minimum Turn deceleration means that the turn that you are already doing, continues long after you tell it not to when set to the slowest speeds and at small stick movements. Mine is also set to 100. So that a turn stops the instant you tell it to, when going slowly. Makes the chair steer properly.
There are about 50 such settings that you will need to fine tune. And these are all down to you. You need a programmer for yourself, not a dumb tech guy or dealer to try to do it for you because they cannot.
