Your motor problem?
Gearbox failed, motor armature, bearing, magnet break up or unstuck, brake seized and not releasing, motor coupling rubber failed and jammed the motor. Are a few of my favorite catastrophies, and I had them all.
I would check to see if it had power going to it before doing anything else.
does the brake click when you try to drive it and click again when you let go of the joystick?
If it doesn't click, check the resistance of the brake coil - should be less than 100 ohms but neither open nor shorted.
Are your joystick lights normal?
Does the right brake click?
If so, then disconnect the left motor from the power module, and look at the plug. Set your multimeter to resistance, and measure the two smaller connections. What does it say?
Do the same with the right motor.
And no error lights?
So are you SURE that theres no click? On left motor?
And on right motor?
Can you turn a wheel by hand if the brake is off
(add 12v to the two small wires).
A lack of voltage from the power module. We can test that later.
Power chair motors are called motors, not engines Never heard them being called engines before! Although I see why Martin calls them engines
Users browsing this forum: acid_coke, Burgerman, Pierro, shirley_hkg and 139 guests
