by LROBBINS » 18 Aug 2018, 10:33
Thanks for all of the suggestions. Here's a summary of what I take from these.
(1) Various greases/waxes can be quite effective. The inside of this tube has a very thin coating of copper anti-seize paste and was not attacked at all by the sea air. However, I can't use these on the outside because it comes in contact with hands, legs, clothing etc.
(2) Barrier or Zn-loaded paints. I can't imagine that any of these would be more durable than the extremely hard and tenacious epoxy that I just used, and some of them are downright ugly. The epoxy will probably yellow with age, but at the moment it's just about invisible and on a test piece I can't dislodge it even with a chisel unless I heat it to >120o C.
(3) Electro plating with Zn sounds like a possibility, but that's a soft coating and would soon get well scratched up (though even scratched it would still protect from glavanic corrosion). It could be chromated (or cadmium plated if I had equipment to do that safely), but I think I would just coat with the epoxy after plating. Still, given how many rusted pieces of Zn plated nuts and bolts I have floating around, it will eventually rust.
(4) Cold blueing might work temporarily, but even black passivated steel eventually rusts in sea air (and, over a longer time span, even around the house).
(5) Will's offer of making a tube out of 416 stainless sounds like a truly ideal solution. If I could find a source here for less than 500 kg and use of a lathe, I would go right ahead and do that myself. But I don't, so I'd really like to take Will up on his offer.
The reason I'd do it myself if I could is that the 16mm ID is not exactly a precise measure as the 16 mm tube is welded A2 and has 2 90o bends in it so it is decidedly not round. Hence, I'll probably have to re-work the bore that Will makes as I did for the cold-rolled on the chair now. It was undersized, and I have neither a lathe nor a reamer that big, so I first used a 16 mm twist drill followed by carbide paper from 200 to 800 grit on the ID as well as using a Norton abrasive wheel to take out high spots on the OD of the inner tube until I got a tight slip fit. On top of cutting out the tapered stair-step interlock, all this took me a tedious 2 or 3 days. I'm sure Will can do better, if I give him close measurements, but some lapping may still be needed.
The mount is in two pieces: the upper piece is 40mm (1.6") long, the lower one is 140mm (5.5") long and both need to be thru bored, so the long one would need to be bored from both ends. Nearest I can tell with a caliper, the 16 mm tube is 16.0 at it's narrowest and 16.2 at its widest, so a bore of 16.2 -0/+0.1 would be pretty close. The short upper tube is a press fit and epoxied.
Will, is this a possibility for you? There's no rush and indeed this will be a backup for the current one for when (or if) the epoxy coating fails.
