Burgerman wrote:No its simple. Unplug the white cell connector. Then snip all those pointless wires off and drop it in the bin. 10 secs.
Yhen you just buy a 8S extended cable, and put the lid back on. I like his cheapo cell log. It is adequate for counting Ah out. Set it to 90 to be safe.
expresso wrote:Burgerman wrote:No its simple. Unplug the white cell connector. Then snip all those pointless wires off and drop it in the bin. 10 secs.
wouldnt you have to cut the power wires also or unsolder them etc, - or maybe not if not connected to the BMS ? just the balance wires seem connected ?
what are those little red wires that are connected to the Red pos large cable that leads outside to the SB120 ?
Gnomatic wrote:With your insane 80Ah add on your tall gearing won't be an issue.
Burgerman wrote:Over-charge Protection"
Over charge detection voltage 3.8~4.4V (can adjust)
This is the voltage it allows a cell to reach before cutting power off from the charger while it attempts to drag the voltage back down to safe levels. Thats way too high even at its lowest setting, and why all BMS hurt cells... PL8 never lets a cell exceed 3.55 or 3.60V during charge and balance. And it doesent keep switching the charger on/off hour after hour as it tries to do this.
Over charge detection delay time 0.5~2.5S seconds.
This is how long it takes after the voltage reaches the 3.8 (minimum) voltage before it switches off the charger. Over and over for hours.
steves1977uk wrote:The higher cell voltage allows faster balancing but at cell life expense, so it's not a great idea to balance beyond 3.6v. Hope this helps SM!
BM - I remember you saying similar about the BMS I posted in the lithium build thread.
I understand what they mean by overcharge protection, but I don't understand why they need it? If the BMS balances the cells at 3.6v +/-0.025v how can the cell voltage ever get up to 3.8v-4.4v
Users browsing this forum: No registered users and 101 guests
