I have been considering putting together a LiFePo4 battery pack for my Magic Mobility X4 wheelchair. I bought this wheelchair as a derelict off of craigslist several years ago. My friend and I spent a few months putting it back into operational condition and it has been a wonderful addition to my wheelchair fleet for the last 3 years.
I use it mainly for outdoor activities, such as getting me to the ski lift for skiing and for hikes on backcountry trails.
A primary limitation of the wheelchair is that it has a very limited range. It will always go 4 miles and on the right terrain will go as far as 6 miles on a charge.
There is room in the battery boxes for a 180AH lithium pack composed of 16 90AH cells. I have ready many posts here about building a battery pack and have done a lot of research elsewhere as well. I think I have the design figured out, but have a few questions about temperature.
Question 1:
I often use this wheelchair in the winter when the outside temperatures reach 0F. While temperatures can get much colder than that here, I could get by without going outside when the temperature is below 0F. During the day, temperatures would typically be above 15F (about -10C). That means I need to be able to operate it in temperatures as low as -18C, but usually above -10C. In this scenario, the battery pack would be charged at normal house temperatures of at least 60F (about 16C) and I would take the wheelchair from that environment directly into the cold. While -10C and even -18C are within the operating temperature range of the prismatic cells I have been looking at (
http://www.evlithium.com/LiFePO4-Battery/472.html), does anyone have an opinion about how practical it would be to actually do so? I am aware that there will be a reduction in available energy, but the trips in the cold are always less than a few miles.
Question 2:
We often go camping at a location where the only practical way to charge the wheelchair is to leave it and the charger in the van overnight with an extension cord to a convenient power outlet. We do this in the spring and fall and camp where the temperatures often reach below 15F (about -10C) and rarely as cold as 0F (about -18C), though temperatures would typically be above freezing (0F, 32C). The spec sheet for the cells says the allowable temperature range for charging is 0C to 45C. My thought was to provide some sort of heat for the battery pack, perhaps via something like a low power heating pad suitable for medical use. Hopefully, that would be safe enough and would provide sufficient warmth to keep the battery pack well above 0C and probably closer to 20C. What are your thoughts on doing this?
Question 3:
To fit the 16 prismatic cells (and insulation material) into the battery boxes on the X4 wheelchair, the batteries would be packed pretty tightly, leaving no room for air circulation. Does anyone see any significant potential for thermal issues caused by the lack of airflow around the batteries?
Thanks for your insights.
