by Burgerman » 04 Sep 2018, 16:32
Settings? Yes many! And you need to completely understand it. And if its configured to use a button to stop in emergency then you need to change this, or add one. DO NOT do this yourself if you dont undrstand what you are doing as you will run away out of control, and or break legs, end up Under a bus... ALL TESTING with wheels raised off the ground.
READ the manuals end to end. Electronic translation is not good enough.
