foghornleghorn wrote::dance Something with a decent capacity that would fit just being 8 cells is what I've been searching for.
D
Burgerman wrote:Looks to me like the 176Ah cells may fit the salsas grp24 battery space.
http://www.lifepo4-batteries.com/sale-1 ... f-car.html
Since the thing is supposed to do an ISO 30 miles, and the 5 hour rate means that it will only actually use around 40Ah of its gel battery then this means a 4 fold range increase, with about 16Ah remaining as a safeguard. So 120 ISO miles... Probably 70 miles in reality. But thats SEVENTY real miles!!! Range anxiety be gone!
And is so I am going to order 8.
The guy emailed back with a price.
For 3.2V176AH Lifepo4 Battery Cell, USD109/pcs (FOB)
6000cycles-5years warranty-lifespan15years-CE/IEC61960 Certificated.
Still waiting on shipping charge. As the best I got was:
if shipping by sea, it costs about USD500 for 1 cubic meter container which holds about 400-500PCS.
But I want 8.. Not 500. And they will sell 1, 4, or 8 no problem. But what about shipping.
Burgerman wrote:Not yet. Stuck on bed, lack of $...
So I would like to know if they fit too. Remember that they need insulation.
Burgerman wrote:The CASE of the cell is connected to the negative on all of the metal case prismatic cells. So you need a 1mm plastic sheet, or similar between the bottom and the sides. And between each cell. So the casings cant touch each other or the chair. Or
too bad i wasnt doing a full chair today
expresso wrote: using 8 Cells just looks so much easier and it is - and more likely for more users to consider doing it -
expresso wrote: but another thing would be - what if 1 Cell is bad or you need to replace later on - would they still carry them - if all goes well - you wont need to replace them at all -
Burgerman wrote:dimensions?
Burgerman wrote:They are just selling connectors plus cells. And no insulation...
The reason I ask is I've been doing some investigating because not being able to get bootcamp assistant to load windows. The HDD has got enough room but not a single large enough sector and needs to be defragged, but there's no tool for OS X 10.14, and I not reloading the operating system, I'm not savvy enough for that. Sorry about the poor grammar, it's early!
Scooterman wrote:With 8 series prismatic cells do you still need a windows machine? You could charge/balance them using just the PL8? When yourself and others charge lithium, you don't plug the PL8 into your laptop everytime do you?
Dan wrote:Or you can save yourself the hassle and buy a used windows laptop from somewhere like gumtree for less than £50.
shirley_hkg wrote: Once configured , you don't need PC anymore.
However , you will miss the fun part -graph- , and can't read over 99Ah returned.
Fedor wrote:But, I think the best option is to use a cheap small laptop (maybe used) with Windows and be able to always see what is happening with your battery.
Users browsing this forum: shirley_hkg and 124 guests
