ZZ or RS means its the exact same bearing with metal SHIELDS designed for use in a place where theres oil to lubricate like in a gearbox or engine. The SHEILDS are not seals, they allow oil in, and anything else, like water or dirt, or fibres in. And they are not lubricated, other than by a trace of oil when new. This evaporates and dissapears. The SHIELD is designed to stop excess oil, which in high RPM operation in a motor couses the balls to skid and develop flat spots. This does not apply to us. And a dampday is all it takes. Humidity.
A RS or 2RS bearing has a rubber lipped metal oil seal, and the bearing is packed with grease for life. The seals keep all the water, dirt out. And keep the grease in. They are used where theres no natural lubrication present, like in motors, wheels, cars alternator, food machinery, etc.
And stainless steel, because the main cause of failure on our chairs is due to corrosion. The zz bearings allow water in anyway. and so rusts... The RS sealed bearings keep water out, unless you use a pressure washer, or hair and fibre get wound into the bearings. That then allows water in... So rust. Stainless steel bearings as used in wet places, like marine use, or food machinery etc, DO NOT CORRODE even if water DOES get in!
So on a powerchair, you want STAINLESS STEEL. And SEALED greased for life bearings. This matters way more than quality, or price. Because the best possible super expensive ZZ Steel normal bearing is NOT lubricated, is not grease packed, and will rust at the first sign of a damp day from humudity alone. Why do the manufacturers use them? Because they never thought about what they are doing or dont give a crap.
And they are cheap and dont fail.
USE these!
2rs sealed stainless bearing search:
https://www.ebay.co.uk/sch/i.html?_from ... g&_sacat=0
