Our electrical carbon brushes are made from low friction conductive carbon materials including copper graphite, silver graphite, natural graphite, electro graphite, resin bonded carbon and pitch bonded carbon.
The combination of this wide range of specialist materials and our highly experienced local technical support network allows us to match brushes and holders to customer equipment for optimum performance with minimal maintenance requirements.
Brush rush
As the commutator and brushes move relative to each other, they wear, releasing fine particles of dust into the motor. As carbon makes up most brush material, the dust tends to be conductive; as it accumulates, it can cause problems, such as slot packing. Slot packing is the dust particles filling the commutator slots and connecting both sides of the segments that are the copper ends of the armature windings where the brushes rub, basically shorting them together. Ideally, the centrifugal force of the rotating shaft will keep the slots clean, but any type of humidity or too slow a shaft speed will contribute to dust accumulation. Motor speed should be a minimum of 1500 rpm to keep the slots clean.
Excessive dust can also cause the brushes to stick or bind in their holders, which can lead to arcing or open circuit failures.
Sparking is another common problem on electric motors. Small sparks are yellow in appearance, whereas large sparks are white. White sparks are detrimental to good motor performance. Sparking can be caused by numerous conditions like motor overload, vibration, high humidity, worn brushes and worn commutators. When checking for sparking or arcing, a good visual inspection of the commutator and brushes will have to be performed.
Users browsing this forum: shirley_hkg and 187 guests
