by ex-Gooserider » 18 Sep 2018, 02:19
As others have said, the controller will shut you down if it doesn't 'see' the brakes - however this MAY be something that can be changed with an OEM programmer, as some have settings for whether or not brakes are installed....
If you don't (or can't) fix it in programming, then you will need to substitute a power resistor in place of the brake coil... You can probably use a larger value resistor than the actual coil resistance (experiment as suggested earlier to see how high a value you can use and still fool the controller) but you will still have some current draw, so you may save the very small weight of the brake coil, but won't reduce your power draw by much...
BM's suggestion of playing with the freewheel switch might or might not work depending on your motors.... Some motors do free-wheel by holding the brake open, and requiring you to spin the motor to push the chair (which makes it hard to push!) and these chairs need the switch to disable the controller so you don't go driving with no brakes... Bypassing the switch lets you continue to drive with the brakes locked open....
Others do freewheel by disengaging the gears in the drive box, which makes the chair much easier to push as you aren't having to backdrive the motors... These often don't have (and don't need) the brake disabling switch since the motors are disconnected from the drive wheels - run them all you want. you aren't moving under power.... BM's switch trick won't work on these...
