by ex-Gooserider » 13 Nov 2018, 06:44
IMHO it is cheap enough these days that everyone should own a basic 6" digital caliper - Amazon has promotions for under $5, regular in the US$10-20 range - digital is easy to read, and gives you both inch and metric (some even give fractional inch) and lets you measure to about 0.001" or 0.01mm with reasonable accuracy - good enough for all but the fussiest of stuff (if you are doing stuff that needs better, you will know it...)
These aren't necessarily be the top quality NIST traceable, etc. but will be close enough for any sort of every-day work... I own a fancy Starrett caliper, but almost never use it, as my cheapo e-bay digital does almost as good and I don't need to worry as much about dropping it or otherwise destroying it...
If you can measure the thickness and width of those copper connector strips, it is a simple math problem to find the cross section area, and then you can compare it to any decent wire gage chart to see what size has a comparable cross section... However I'd be willing to bet they are at least as good as AWG 10, probably better - no real need to double up...
However you do need to make sure that any fasteners you use are able to snug down tight, with NO movement of the hardware under them - if there is slop you WILL have connection problems, and they will be intermittent and difficult to find... So use the shorter screws / enough washers to make a snug fit...
