by Burgerman » 22 Nov 2018, 02:11
Yes. If you put your hand on them after a days use they generally feel warm. Compared to sat the bench, or an internal wall. This is because of resistance. And when you charge, that too warms them a little.
The problem is this. The warmer you get the batteries as you charge, the lower the voltage needs to be. But we dont lower that. So then the battery gets even warmer. Which needs an even lower voltage. So its possible that instead of dropping as the battery becomes full, the AMPS begin to increase again... This results in a thermal runaway and ruins the batteries, smells bad...
So if in doubt use a little lower volts. That takes longer but is safe. At 25C the highest is 14.1v per battery. But 14V is safer. And 13.9V is fine too, but charges slower.
