expresso wrote:
Dimensions:
(L) 259mm x
(W) 169mm ( 2 X 169mm ) x
(H) 178mm.
this is the info i was given
shirley_hkg wrote:expresso wrote:
Dimensions:
(L) 259mm x
(H) 178mm.
This would be excellent @£35.00 , if you could expend a few mm at the total width .
expresso wrote:12V 60Ah Deep Cycle GEL Battery M34 SLD G
Dimensions: (L) 259mm x (W) 169mm x (H) 178mm.
snaker wrote:These 8x120Ah cells are a little bigger than your box size.
https://item.taobao.com/item.htm?id=530722922690
It seems the box size 18x35x17.2cm is not correct, it is unable to fit 2x60Ah lead battery. You should measure it accurately. It might fit 8 cells above.
Brand: *TL
Aluminum shell power battery
Specification: 3.2V120ah
Size MM: Thick 48* Wide 173 * High 168
Voltage: 3.2V
Nominal capacity: 120Ah
Measured capacity: 118-125AH
Internal resistance: about 0.3 milliohms
Discharge cut-off voltage: 2.0V
Charging limit voltage: 3.65V
Maximum charging rate: 1C (recommended 0.2C)
Instantaneous discharge rate: 3-5C
Charging method: CC/CV (constant current and constant voltage)
Weight: 2.8KG
Cycle life: 2000 times or more
Burgerman wrote:That will fill about half of a grp 34 battery area. They will be hiding in the corner trying to keep warm!
These are 200 long, and 8 is 272 wide.
You have 260 x 344...
Burgerman wrote:If those will fit, yes. More Ah means a lower C rate is required since theres more Ah.
Burgerman wrote:Yes. But not yet. My fridge freezers bust!
elryko1992 wrote:Burgerman wrote:That will fill about half of a grp 34 battery area. They will be hiding in the corner trying to keep warm!
but this is more good: https://www.lifepo4-batteries.com/sale- ... orage.html
and charging\discharging C is good?
Users browsing this forum: mrgus2u and 77 guests
