rlnguy wrote:It's not uncommon for foam filled tires to develop soft or flat spots, especially, when they get older.
It's not unheard of on new ones, either, for that matter.
Sometimes, a good close inspection, using your thumb to press the tire, in different spots, will find it.
First, check if it consistent with the speed of the tire-mark a spot on the tire, with a marker, or piece of tape, drive the scooter, while watching the mark-if the mark is in about the same place, every time it thumps, you're on the right track.
In my experience, a tire is the most likely cause, from your description.
good luck
flagman1776 wrote:Now that the power is back on... I just felt the tires on the spare scoot (on the work table)... rock hard. Can one feel soft spots in a foam filled where the foam is failing?
Users browsing this forum: No registered users and 70 guests
