Burgerman wrote:Says driver error...
Go to device manager. Delete the bt device with driver error, and all previous attempts at connections from the older BT thingy using up serial ports. Choose show hidden devices. And delete all the greyed ones.
Then reboot, check the unused serial port is disabled, and that both are 19200.
So welcome to the BT PL8 elite club!
Wires? Were we're going we dont "need" wires... @ BTT Future.
Burgerman wrote:Much testing later.
Charge between 20mA and 700mA and it behaves perfectly. From 700 to 800 its intermittent and loses contact. 1A and it fails every time at about 12 to 24 secs after charge begins as the current begins to ramp up. And doesn't reconnect without stopping everything, and restarting PL8 and BT off/on. Does not matter what the source of power is, Same on power supply or a battery.
So did you fix it by fitting 2 capacitors and a resistor? Did you use a schottky diode?
expresso wrote:i would be interested if i can buy one ready made from woody etc, plug and play - i dont feel good about opening my charger up etc, - with my luck - i toast it =
with the Power supply cable - how do you use the power cable if its connected to my PSU ?
Burgerman wrote:They already have. But I hate phones and the thing usesthat terrible bump charger interface and has different options. When they do a windows CCS I will buy one and test to see if its any use to us...
Burgerman wrote:Only you will know!
Its easy enough.
And yes I have occasionally held the hot end. Hurts. Soon let go.
Users browsing this forum: No registered users and 55 guests
