The fact that they are basically a firework, means that you see rather exiting fires from teslas now and again. In spite of the cells being heated and cooled by water and monitored very closely. And built into huge grids with each cell fused individually in a very clever design to try and prevent any chain reactions getting going. But in a car, that pack sits under the car which is a metal box to allow you to stop and get out. A wheelchair user such as myself doesn't have that option, and we are usually indoors too.
Tesla use a very careful management system, and around 66 percent of the rated capacity to get their endurance. And again they are using a very large capacity pack. The reason they do so is not only to get up to 300 miles per charge, but because theres only one way to get high cycle life from lithium packs.
They will give very high numbers of cycles if not worked hard. And the opposite is also true. So lets say your 120A Rnet chair can take 120A periodically. And 200A frequently when zero turning. Or when ramp/curb climbing. And lets say you only have a 40Ah pack as you propose. That means that your cells will be very heavily loaded (Amps) regularly. The relationship between how much a lithium cell is loaded and its cycle life is almost linear. I use those lithium ion 16550 cells in some hobby stuff. After 100 cycles, charged extremely accurately they are toast. Yet the exact same chemistry used in my phone, which is a much lower peak pulse load, and a low C rate that is charged daily is 2 years old. The relationship between current and cycle life is huge. So the difference a 120 to 180Ah pack makes to longevity and reliability of all lithium is huge. It makes looking at cycle life figures almost meaningless. Which is why most manufacturers quote cycle life based on fractional C rating or at best 1C.
The next thing is charge volts, depth of discharge and frequency. With a 40Ah pack you will get just 25Ah from it if de-rated in capacity to avoid the effect of trying to get peak Ah from the cells. Tesla charges to 4.1 volts, and only discharges by 70% DOD or 30% State of charge minimum. Thats how they unlock an extra bunch of range in times of floods or tornados as seen on the news. This is why:
Please spend a little time looking at this page, it is accurate and informative, and relates to lithium ion chemistry that you are talking about.
https://batteryuniversity.com/learn/art ... _batteriesThere are many things that shorten the service life of lithium batteries.
That capacity rating you quoted for the cells I linked to is wrong. That is their WARRANTY. It is expecting them to be used with a small pack, and with a typical BMS and those things universally screw up LiFePO4 cells.
The actual well tested and proven cycle life of LiFePO4 cells is:
1500 cycles at 100% DOD to an end point of 80% original rated capacity.
2000 cycles at 80% DOD to an end point of 80% original cap.
6000+ cycles to 60% DOD etc...
I have the full detailed test and spec sheet here should you wish a copy?
Those specs are when charged to a torturous 3.650V. We generally use a very controlled charger, accurate to 3mV, that has a 1A balance control, and is highly programmable. And we charge to a lower 3.550V per cell. That costs around 1% of capacity on a LiFePO4 cell. That alone, means more cycles that the specification.
And because we use typically 120Ah to 180Ah we are loading the cells very lightly, at around 1.2C peak. And a fraction of 1C much of the day (week!) And because a large pack gives us an enormous range, then we seldom need to charge more than say weekly in winter, or maybe twice a week in summer that multi thousand cycle life is decades. And no more range anxiety, the pack runs down slower than you do.
And because that end of life point is 80% of 60 or so miles, its not really end of life at all. Because even at 10,000 cycles we still have more range than lead! Or a 40Ah new pack. In other words the battery will outlast at least 2 powerchairs. And we dont burn. And they are cheap even doing a DIY setup with 5x the range!
Dont get me wrong. A small firey lithium pack that is easily unclipped and removed in the event of fire does make sense on a travel chair, or a small scooter. Or even a hover board balancing thing like all those that were catching fire 2 Xmases ago. And thats exactly where you do find them.
