R-net controler thingy info
Postby funkykeyboard » 23 Jan 2019, 10:04
I want to connect my lights and back rest recliner and leg bag empty so I can control them using the pod using the generic F55 methodology.
Firstly, I don't know what the thing called that you plug into the R-net controler, that you then plug your recliner motor, lights, and any other peripherals? (This is the thing on my lifestand wheelchair https://gyazo.com/bdaed17333ecf9981147b630ceebebdb
I cannot see any stickers to identify the version of R-net controler I have, is there a way to identify it? So I can order the thing above I don't know the name of that is compatible with my R-net controler. (I do have the R-net controler programmer. Could I use this to identify the R-net controler model number?)
funkykeyboard
Re: R-net controler thingy info
Postby steves1977uk » 23 Jan 2019, 12:14
It's this... http://www.cw-industrialgroup.com/Produ ... ing-Module
But the actuators/channels will need programming, which can be done but complex to set up.
There should be a square box on the R-Net PM's label which says 60, 80 or 120. This is the amp rating. Or use the programming software and look at Boost Current, if it says 120 then it's a 120A Power Module.
Postby funkykeyboard » 23 Jan 2019, 15:40
So that is just the seating module, Steve? I need another module for the front and rear lights and indicators and my leg bag emptier?
funkykeyboard
Postby steves1977uk » 23 Jan 2019, 17:21
No, the ISM has more outputs than the basic seating module here... http://www.cw-industrialgroup.com/Produ ... ing-Module
There's also the Intelligent Seating/lighting Module (ISLM) here... http://www.cw-industrialgroup.com/Produ ... ing-Module which would operate the seat and lights, but unsure how you'd connect your leg bag emptier to the module unless there was a free port assuming you don't use all the seating functions.
Postby greybeard » 23 Jan 2019, 17:52
If FK only needs a power take-off he could use one of these Rnet bus connectors. I had one originally on my first Puma but can't recall what was connected to it, or where it went for that matter, otherwise I would gladly donate it. Although it's shown here, I can't find it listed. Easy enough to incorporate a switch to activate the legbag emptier.
http://sunrise.pgdrivestechnology.com/pdf/r-net.pdf See bottom centre of the diagram on the first half of page 2.
Postby steves1977uk » 24 Jan 2019, 11:24
I think FK wants to use the joystick to activate the leg bag emptier.
Postby Burgerman » 24 Jan 2019, 11:46
And is talking about the olde world F55 I think. Unclear. Which never had R-net.
Postby ex-Gooserider » 29 Jan 2019, 02:55
IIRC, the F55 used Pilot+, which had similar modules for seating function, lights, etc. - different hardware but same idea...
Burgerman wrote:And is talking about the olde world F55 I think. Unclear. Which never had R-net.
Postby snaker » 29 Jan 2019, 03:17
The blue switch is my ''leg bag emptier' :evil:
Postby Burgerman » 29 Jan 2019, 03:31
Hopefully not pressed while indoors by mistake? :mrgreen:
Postby snaker » 30 Jan 2019, 03:43
That mistake only happens when I am in enemies houses, free-fire :mrgreen:
Postby funkykeyboard » 10 Jun 2019, 12:31
steves1977uk wrote:It's this... http://www.cw-industrialgroup.com/Produ ... ing-Module
finally got round to doing this job and finding out that the power module is 120 amp.
I've just sent this message to the website you recommended.
I wanted to purchase the;
R-net ISM-6 6 channel Intelligent Seating Module
120 amp
and the cable.
Can you tell me how I go about that please?
unless anybody else knows where I can purchase this product?
funkykeyboard
Postby Burgerman » 10 Jun 2019, 12:37
A chair manufacturer. $$$$$$$$$$
PGDT if they think you know what you are talking about. $$$$$$
EBay. $
Have a read.
viewtopic.php?f=2&t=8857
Postby rover220 » 10 Jun 2019, 15:04
there are 2 cheap 120a modules on ebay at the mo
Postby funkykeyboard » 14 Jun 2019, 14:01
I'm looking at the serial numbers on the labels and I don't know whether they need to marry with each other, or whether all seating/lighting modules and the power modules are compatible?
So if I buy this Https://www.ebay.co.uk/itm/254244235776
Will it be compatible with this
https://gyazo.com/e36b5a9a0eb0d3d9b36db09c09d6c6e3
Secondly, I can find these buss cables, but I cannot find the cable that connects the power module to the seating module, does anybody know what it is called?
https://www.ebay.co.uk/sch/i.html?_from ... e&_sacat=0
funkykeyboard
Postby rover220 » 14 Jun 2019, 14:15
those cables are all you require to connect any module into the system, all modules are compatible save some potential programming issues
Users browsing this forum: Burgerman, woodygb and 14 guests
