Oh that will go over real good with the company providing my batts. The man is already PO'd because I told him to take those back. Typical situation where the DME doesn't want the user to actually have any knowledge whatsoever on the equipment they use, and when you do question them or demonstrate concern or knowledge, they take it as a personal attack.Burgerman wrote:Well again. MKs are gel. They need to be charged at 14.1V or 28.2V for the pair.
And very thoroughly like for 16 hours befre you use them. So that basically rules out a mobility charger...
Also before fitting both should be charged 100% individually. Or connected together for 24 hours in parallel before fitting. And rejected if either is below 12.7V on arrival.
woodygb wrote:A bit of digging shows that they are made by East Penn.
http://www.eastpennmanufacturing.com/ea ... batteries/
MK are also owned by East Penn
I cannot find any meaningful specs on the Duracell.
woodygb wrote:Two of these ? ... They appear to be less than half the price of MK's.
https://www.batteriesplus.com/battery/m ... m/sli24mdc
Users browsing this forum: Bing [Bot] and 84 guests
