Any other manufacturers/models worth considering?
martin007 wrote:
Sonnenschein
MenCallMeGimpy wrote:
I thought about Odysseys, but remembered the size issue and, since I can't get to the battery box to measure, don't really feel comfortable ordering them on faith.
I'll definitely check out the Sonnenscheins and MKs, though.
Gnomatic: "As far as chargers, consider the ZXD2400 from shirley." Thanks for this tip! I've started to read the fascinating thread on this, but I'm guessing I can't use Shirley's charger through the normal three-pin socket on the joystick pod? Looks like I'll need to wire Anderson clips directly to the batteries.
It looks like these are the ones I should be considering: http://www.ezmobilitybattery.com/mk-bat ... 4sldg.html Based on your experience with the V6, do these look right? The V6 user guide says 73ah, but I figured 74ah was close enough (since MK don't make a 73ah battery).
Gnomatic wrote:Those are the right ones, though I would go with the flat top version of that battery for the V6.
http://www.ezmobilitybattery.com/mk-bat ... ldgft.html
Gnomatic wrote:
No, you can certainly charge through the joystick pod @12A. BM made a video of the charger doing precisely that!
http://www.wheelchairdriver.com/gopro/3stage.mp4
It makes an excellent, versatile charger.
LROBBINS wrote:Can you post a link or part number for the fans that you've found suitable? I have one of these power supplies in fancy case and it's really great, except for the loud fans. Strangely, in charger mode as current flow drops the fan speed does drop some until it goes to float, when the fan goes once again full tilt. Not the best programming.
The average price of a litre of fuel in the UK is now around £1.20 for petrol and £1.29 for diesel.
Users browsing this forum: shirley_hkg and 37 guests
