terry2 wrote:Burgerman wrote:Ring terminals. Cable. Solder. Heatshrink. Anything else is a bad idea.
What is the best size for the cable? 8 AWG?
BM uses 10mm^2 - which is theoretically equivalent to AWG 7, but while they have size specs for it, odd number AWG sizes are not normally available... AWG 8 is a bit smaller, and probably adequate... AWG 6 is larger, and on the 'overkill' side... Take your pick... Worth noting that the most commonly available pins for Anderson SB-50 / PP-75 connectors are sized for AWG 6, so it takes a bit of extra crimping or stuffing with filler wire to use smaller wire sizes.
I would look at the wiring used as stock on your chair and go for AT LEAST that large, and consider larger as IMHO many manufacturers seem to undersize their wiring, especially on a chair like yours which sounds like you may be more likely to use in high current load conditions...
I like welding cable more than the tinned marine wire - it seems more flexible, but either will work.
