by iainsherriff » 20 Feb 2019, 10:50
Interested to see where you go with the center plate.
Matt's Salsa M2 has manual folding center rest. It came as two plain aluminum "paddles" linked together at the hinge. Needles to say the front edge dug in to his heel when placing his feet and the back hinge area did so when his feet where in place. I added carpet and rubber edging which worked for a bit. Then he needed more padding so WCS sent out some gell pads, which didn't fit and the thickness prevented folding. Placing them far enough apart and re-drilling allowed them to be fitted and they ARE confortable BUT are too wide for when Matt transfers (they place his feet too far apart for strength to push off).
Ideally we want a plate to sit at the floor level for mount/dismount but that means no padding. OR to have the plate fold and move out of the way (backwards maybe).
Matt has to lift/push/pull his legs into place using his arms/hands but struggles to reach down to plate level so it needs to be powered.
We need center mount to maintain maneuverability in the house..... such a small thing but (as you say many times BM, OEM chair design and build IS rubbish)
Matt (son) is chair user.
MS fairly advanced
Invacare TDX SP2 NB
TGA S4 for dog/kid walking
