laoshanren wrote:woodygb wrote:You should supply the details like this ...
I am using a software program X on my P.C. to try and communicate with Q6 logic controller ( part number ) using USB interface type Y ( plugged into the pods charging port ? ) with settings Z.
I guess that your using Curtis 1314 programming software ?
Thank wood,
I'm using 1314 - 4402 try to modify the Q6 power module, the communication is OK, just don't know which function should be disable now.
Also, do you know what sensors JACK SOCKETS these two round white are? how to disable them?
–On/Off Jack Supervision:
The on/off jack supervision parameter can be used when an on/off switch is connected
through the on/off jack. When programmed to YES, it monitors whether the switch is connected; if the switch becomes
disconnected, a warning is issued.
# The settings for this parameter are YES and NO.
–Mode Jack Supervision:
The mode jack supervision parameter can be used when a mode switch is connected through
the mode jack. When programmed to YES, it monitors whether the switch is connected; if the switch becomes disconnected, a warning is issued.
LROBBINS wrote:The BUS does not carry the analog joystick output. It carries serial digital messages. What Woody is suggesting is connecting a voltage source to the wires inside the pod that go from the joystick pot to the circuitry. Then your analog voltages will be converted by the circuitry (micro computer and associated chips) to the proper digital messages for the rest of the system.
Yes..... but why not use a simple voltage divider ?As the VS/2, if I keep the original joystick, can its P6 (Centre tap) work as VS/2?
my new potentiometer joystick has : 0 - 2.5 - 5.
woodygb wrote:Yes..... but why not use a simple voltage divider ?As the VS/2, if I keep the original joystick, can its P6 (Centre tap) work as VS/2?my new potentiometer joystick has : 0 - 2.5 - 5.
Your making things very complicated for yourself!
Just feed 1.3V to the GND pin and 3.7v to the 5v pin....
Grab yourself 3 of these and you can use them as voltage dividers for setting your joystick feed voltage end points and for setting Vs/2.
3296 Multiturn Variable Resistors - Potentiometer, Preset, Trimmer, Pot
woodygb wrote:
Note that I always provide my own separate 5v supply rather than using the pods ... as the pods 5v supply has proved to be problematic.
The bus is a CANBUS
woodygb wrote:It doesn't need a hall effect joystick ...I've made many using a digital pot as shown in the drawing.
It's just requires a simple voltage swing BUT the voltages must be correct .... especially the initial neutral voltages.
woodygb wrote:Try this....
LROBBINS wrote:The serial digital of a wheelchair bus will probably NOT match whatever digital signal you can get from your RC. The most common wc serial is one or another variant of CANbus which has a quite specific packet structure, de-ambiguation protocol, and checks for intact messages. (The Dynamic Shark uses an RS-type serial (don't recall which, perhaps RS482), but it's an exception, and the messages still have to match what the power module knows how to interpret. Woody has had ample experience hooking external devices to the joystick connections that are inside the joystick pod - follow his lead and you will have success.
laoshanren wrote:woodygb wrote:Try this....
Thank you Woody,
The PAD still not recognize the new joystick, just shown error #35,36,37.
The Voltages power on: 5.7 , 0 , 3.55, 1.75, neutral 2.6.
The X: 3.36 - 2.43 - 1.75
The Y: 3.54 - 2.61 - 1.76
Can be better if I use 4 Potentiometer to set the numbers same as you diagram?
Users browsing this forum: Mr.Math, shirley_hkg and 133 guests
