Hi everyone from warm sunny Spain. I have just ordered some 74ah MK Gel`s ( thanks for the link Martin 007) and just double checking that will be going about it the right way when charging up. I will charge each one individually with a 12 charger from around 20 to 24 hours before putting on the chair. If i was to make up some leads so I could charge them both in Parallel was size mm thickness wire would I need. I have read ( but not always fully understood ) a lot of threads on which is the best charger, but for a complete electrical novice could you advise on a good charger. I am not a full time chair user but I definitely need one when out of the house. I currently use a P/N 240700 input AC100-240v 47-63Hz output: DC24V7A which apart from the 24volts 7amps at the end the rest is complete gobbledygook.
Take care everyone
Graham
