Hi Flagman,
No there is no ball hitch.
How it works is that instead of a ball it uses a relatively chunky spring (about 1" diameter) to allow the trailer the articulate side to side, and up and down (pitch and yaw?)
The spring is mounted longitudinally but and there is a solid piece of nylon inserted up the middle of the spring that stops the spring from stretching lengthways, but still allows the spring to bend from side to side, and up and down. I guess it's simple and cheap and okay for cycle trailer that isn't suppose to be lugging heavy loads.
This is the same trailer
https://youtu.be/kGQdzLkw2OY, you can see the spring arrangement at 1:05 secs. I drastically shortened the length of the tow hitch arm and also put a smear of graphite grease on the connector. So mine couples really easily, and likewise when I press the release button it uncouples really easily as well. The guy in the video seems to struggle a bit with his. Plus mine doesn't overturn.
