ICEUK wrote:Where r u. I have a pair rims for the 300-8 tyres.
hotwheels_75 wrote:My rims aren’t wide enough and the inner half of the rim isn’t drilled for a valve stem. I tried to mount a solid 3.00 x 8 tire on the rim and there was no chance. There was at least a quarter inch gap between the rim halves
hotwheels_75 wrote:Anyone know of other wheels that will fit? I could go aftermarket/custom with a homemade adapter plater,
Burgerman wrote:And 110/80 or 120/70 -8 on tubeless on 3.5 wide rims as I used on the salsa...
shirley_hkg wrote:hotwheels_75 wrote:Anyone know of other wheels that will fit? I could go aftermarket/custom with a homemade adapter plater,
You have the freedom that not many people have then.
These wheels are just $40 CAD a set.
Many sizes to offer. Most of all , they are tubeless , so much safer and last 5yrs easily .
hotwheels_75 wrote:That’s a problem, was trying to keep it within 26”. I’ll look once I get the bugs worked out. Might have to be 3.50
I’m ready to test fit and drive it but I need to reconfigure some seating controls in the software can’t find the right option I settings. I need to set it for tilt that each time i push the joystick forward it changes tilt direction. Right now I have to pull back to tilt back and push forward tilt it forward. I can invert them but don’t see the option I want.
Also I get an warning that my software is older than than the file on my chair when I connect it.
Users browsing this forum: mentado020477, shirley_hkg and 33 guests
