by ex-Gooserider » 16 Apr 2019, 01:59
Worth noting that the stock Invacare rims will require use of tubes, and the resulting unreliability of tube tires... It might be worth considering the tubeless rims and tires that you can get via Shirley.... They will require making an adapter, but Tubeless is much less likely to get flats...
Also note that the size increase may be more than the nominal tire sizes would suggest - The 350 x 8 tires on the wheels I got from Shirley are just about exactly 3.5" but the nominally 300 x 8 stock grey solids that came on my H-frame project chair were closer to 2.5"
