by expresso » 19 Feb 2020, 03:18
tires tubes etc, not worried about stocking them - i have a few just in case i can easily swap out the whole rim tire - then change a tube and get another one for back up - since i use the same caster tire on 3 chairs - i have a few sets of tires and tubes for the casters - one set of tube for one chair rear tires -
other chair rear tires - i have whole set or rims with tires mounted and ready to just swap if needed - that gives me time to then get another tube or tire and go to bike shop to install - - only casters can be done here - thats easy enough - but the bounder chair is a different story - thats a bit more complicated on the rear tires
i may or would call the tech. to do that for me if and when needed - i am hoping its only needed once year when changing worn out tires - i know i will wear them out during the summer - then put in for new ones in the winter and start over - new tires - clean chains - sprockets - brakes etc, thats the winter tune up on that chair
Quickie P222se - 60Ah ADD ON
Quickie P220 - Indoor Chair
Bounder Plus - 180Ah LifePo4
