White Lightnin' wrote:Was Jason a part of the business the first time around? One motor on my chair started leaking almost as soon as I got it. I was lucky the salesman was able to get it replaced. The chair won’t go above the speed allowed when the seat is raised beyond a certain point right now. I think it is probably due to a bad switch, but I’m not sure where to start first. I liked the chair and want to get it going again so I can put some of the wider/softer tires on it.
White Lightnin' wrote:I have a Balder power chair from a few years back that came with Sonnenschein batteries. From looking at the Sonnenschein website it looks like they are one of the 512xx... models. To make sure I don’t order the wrong batteries, can anyone tell me for sure which model? The chair is a front wheel drive model about five to ten years old.
Burgerman wrote:Any 22nf sized batt will fit. But its too small for purpose so you are wise to buy either MK or Sonenshein. The MK is actually better spec, and has a slightly better cycle life at 500 cycles to 80% discharged. Compared to 450 cycles down to 75% DOD. But then its also more expensive.
Burgerman wrote:gf1244y is a 22nf case size. But its true that they dont all measure exactly the same. The sonnenshein is about 3 or 4mm smaller in every direction. But grp22nf should all be similar/swappable in theory. But sometimes not...
I’m searching for a variable voltage charger now with somewhere around ten volts to charge an MK or Sonnenschein battery.
Users browsing this forum: martin007, Raro, woodygb and 82 guests
