The inhibit wire is either made High ( 24v + ) or Low ( Gnd )....to prevent the chair moving when being charged.
Inhibit LOW is the norm but onboards can be inhibit High.
REMOVE / Unplug the onboard charger ...THEN.
If your feeling brave, jump a temporary wire from the GND pin 2 to the middle INHIBIT pin 3 of the pods charging socket....try the chair...if that doesn't work switch over to the Plus + pin 1 .
And yes it can be altered in settings.
