Burgerman wrote:Battery is bad. Most likely.
Burgerman wrote:You dont charge a battery UP TO a voltage. You charge a battery AT a specific voltage.
You charge gel at 14.1V per battery. And AGM at 14.4V per pattery. You do this for around 12 to 16 hours. Or until current falls to a very low level (1000th of capacity). Then its charged.
The measured voltage will vary over time with a healthy battery.
Straight after charge, it will fall rapidly from around 13.6 to 13.2V. then it gradually drops to 12.85V (agm) or 12.9 to 12.95v (GEL).
I suspect both your batteries are
Burgerman wrote:Snake oil. A smart charger cannot recover anything other than a battery that needs charging. And most so called smart chargers are big on marketing and dont charge anything properly.
If your chargers are working, and one battery is below 12.9V after charging, before use, then the battery is faulty. Or just worn out.
Burgerman wrote:A battery that reds 12.0V (24V) is already dead. You will be going nowhere.
That means the battery effective scope of use is only from 12 V to 12.9 V, can this let the chair run 10 miles even more accord to the manual?
Mechniki wrote:At that point I stopped and plugged in the LifePo4 into the XLR port, got the green light back. Made the rest of the way home (about 1.2 miles), without losing the power.
Burgerman wrote:When the lead battery runs low, connecting a higher voltage lithium, esp one thats fully charged, will then dump all the lithium power into the lead battery. So yes it will charge the lead as you drive. But that is absolutely the wrong way to do it.
Because you drain the lithium fast which it hates, and will possibly shorten the lifespan fast. But also because the lead suffers more from deep discharge, and gives less range because of the high peukert value.
The correct way is to begin with both batteries fully charged. And link them. Then as you drive the power initially comes from the lithium, and as you go further it starts to come from both. You hurt the lead and the lithium less, and get mote total range. Likewise they can be charged as one battery at 28.80V.
One more question is my two GEL batteries dropped from 25.4 to 23.5 in 10 - 20 minutes, and charged from 23.5 to 26.5 in also short time say 20 minutes, is this normal ?
Actually I'm trying to mix the SLA lead acid and gel, they have almost same V, is that OK?
Burgerman wrote:One more question is my two GEL batteries dropped from 25.4 to 23.5 in 10 - 20 minutes, and charged from 23.5 to 26.5 in also short time say 20 minutes, is this normal ?
Yes,and it means little. It beccause of something called surface charge.
If I take a brand new and just charged battery and start a car with it, it will use around 1Ah. So that battery is still full. But its voltage drops below 9V while cranking the engine and will then gradually rise over the NEXT 24 HOURS back to the fully charged voltage if you were to disconnect it and wait.
Likewise if I take an identical fully charger battery and take out 1A for 1 hour it will still read 12.9V... Both will have different voltages, and be equally charged.Actually I'm trying to mix the SLA lead acid and gel, they have almost same V, is that OK?
No... In series at leat. You will destroy them while charging.
And in parallel, you can safely charge at the gel voltage, (14.1V max) and that will leave the AGM/sealed battery undercharged.
any thing wrong inside?
LROBBINS wrote:any thing wrong inside?
Yes, probably a shorted cell. There's no resurrecting it.
Burgerman wrote:You can charge any battery or cell to more than its correct voltage. It doesent mean its any good.
If you charge a single 12V battery correctly, it will read 13.4V approx directly after charge. This will fall over a few days in a ever slowing amount until it reads around 12.95V. This is all the same 100% full. If you wait a few weeks, it will read around 12.85V and still 100% full.
If after charging your battery is less than these figures. Its ruined. Permanantly. It may be 1 cell thats bad, or 3 that are not as good, or whatever. It doesent matter. Its only fit for the bin.
Also even if the voltages read as above, that still does not mean the battery has the ability to deliver any real current. It may be high resistance. So if voltage falls a lot under load it is still junk.
Also... Even if the volts are as above. AND the battery can deliver enough current to drive the chair, it may be severely lacking Ah, and so have very little range.
The reality is that unless the battery is under a month old (use) then it will already show at least some of the 3 issues above to small levels. And this gets worse over time.
Burgerman wrote:Rubbish. Any lead battery sat at 10V or less for more than a week is ruined regardless of any amount of messing about with it. Depending how long = HOW ruined...
You CANNOT desulfate or repair any battery THAT IS PERMANANTLY SULFATED, or that has used up its active plate material, or that has internal corrosion, plate swelling or distortion, internal shorts etc by pulses, frequencies or any other means. Thats all snake oil.
You can remove some non permanant sulfates back to the acid, if its a healthy battery that has beel discharged for a long time if you are lucky by a very long slow charge over a few days at a controlled voltage /current. The act of charging IS desulfation. But it will never be as good as it was. And probably junk. And non of this can be determined by measuring voltages. I have a bunch of completely knackered batteries here that are all sat on the shelf at 13.0V.
Users browsing this forum: biscuit, FrontierNZ, UnicornBurner, woodygb and 26 guests
