bought a used wheelchair
Re: bought a used wheelchair
Postby danmcclain2019 » 14 Jun 2019, 22:21
still no power to the pod
danmcclain2019
Postby woodygb » 14 Jun 2019, 22:36
danmcclain2019 wrote:when I put the negative probe in round pin hole 9, and use the positive probe on 5 slot and 6 slot I get 25v on 5 and 6 (on the 9 pin plug)
Pin 9 is the solenoid parking brake.
There should be power between pins ( 5 & 6 ) and ( 7 & 8 ) ... nothing will work if there isn't.
Postby danmcclain2019 » 14 Jun 2019, 23:13
on the 9 pin plugin I placed the negative probe in #9 round hole and used the positive lead to check both 5 and 6 slots which both read 25v, still no power to the pod
danmcclain2019
Postby woodygb » 14 Jun 2019, 23:15
Why are you using pin 9 ?
You need to use the 0V ( 7 & 8 )....
pins ( 7 & 8 )connect to your battery negative.....pins ( 5 & 6 ) connect to your battery positive.... pin 9 goes to a solenoid brake.
Postby danmcclain2019 » 14 Jun 2019, 23:23
there is no power reading between either 5 ad 6 or 7 and 8, wired go directly from the batteries to the 9 pin no connectors inbetween
danmcclain2019
Postby danmcclain2019 » 14 Jun 2019, 23:28
ok there is 25v between 5 and 7 and 25v between 6 and 8
danmcclain2019
Postby danmcclain2019 » 14 Jun 2019, 23:35
I guess my basic knowledge of electricity isn't going to get me through this, getting a headache
danmcclain2019
Postby woodygb » 14 Jun 2019, 23:35
Good.
Note that pins ( 5 & 6 ) and pins ( 7 & 8 ) are actually connected together inside the socket .
You should now have power to the pod when you put the 2 plugs into the sockets ...this doesn't however mean that the pod will work .
Postby danmcclain2019 » 14 Jun 2019, 23:37
Plugged in the two plugs, the pod will not turn on
danmcclain2019
Postby woodygb » 14 Jun 2019, 23:38
Where in the world are you Dan ... e.g. U.K. & approx location or ?
Postby danmcclain2019 » 14 Jun 2019, 23:39
could it be a bad keypad?, I did take it apart and clean the contact like the video you provided said to do...
danmcclain2019
Postby woodygb » 14 Jun 2019, 23:41
You can try turning it on by flashing across the internal contacts quickly with the tip of a small screwdriver or similar.
Postby danmcclain2019 » 14 Jun 2019, 23:42
I'm in Hot Springs, Arkansas, United States, could find where to fill out a profile sorry
danmcclain2019
Postby danmcclain2019 » 14 Jun 2019, 23:44
I'll try the flashing the contact
danmcclain2019
Postby danmcclain2019 » 14 Jun 2019, 23:45
may take a few minutes have to disassemble it again
danmcclain2019
Postby woodygb » 14 Jun 2019, 23:46
OK ...I was going to suggest that you send it to me if you where in the U.K.
Go to the User Control Panel ( towards the top left of the page ) ...click on it ..Then ... Profile ...Scroll down for Location.
Whilst you have it apart check for 24v between the RED and BLACK wires that push onto the spade connectors.
Postby danmcclain2019 » 14 Jun 2019, 23:57
Woody it worked, the flashing with a screwdriver worked!!! I guess I need a new keypad right?
danmcclain2019
Postby danmcclain2019 » 15 Jun 2019, 00:00
k checking the red and black wires for 24v
danmcclain2019
Postby woodygb » 15 Jun 2019, 00:00
Good news.
You can also try re-surfacing the black pads with a a soft lead pencil (a #2/HB, B or softer).
Postby danmcclain2019 » 15 Jun 2019, 00:10
tested the red and black wires inside the pod, have 25volts reading, I also noticed on the inside of the keypad all the button had a little head on them except for the power button, it was missing
danmcclain2019
Postby woodygb » 15 Jun 2019, 00:14
Ah! ... you will need to either replace it with something similar or purchase a new pad.
Postby danmcclain2019 » 15 Jun 2019, 00:17
Woody: I could not have done this without you, you saved me lots of money that it would have cost to repair the chair, I really appreciated your help, thank you :thumbup:
danmcclain2019
Postby danmcclain2019 » 15 Jun 2019, 00:19
will order a new keypad...Thanks again Woody have to go for now....Bye
danmcclain2019
Postby woodygb » 15 Jun 2019, 10:17
Postby Burgerman » 15 Jun 2019, 11:02
May be chea[per to just fit a tiny momentary switch elsewhere on the pod. Drill small hole. Small wires and a soldering iron...
https://www.google.com/search?client=fi ... 46fku2bkjM:
Postby Scooterman » 15 Jun 2019, 11:39
Burgerman wrote:May be chea[per to just fit a tiny momentary switch elsewhere on the pod. Drill small hole. Small wires and a soldering iron...
Good idea, I would try that. Small outlay and nothing to lose. Could always by new one as spare.
Catz ‘r’ kool :admirer
Postby danmcclain2019 » 15 Jun 2019, 12:05
Think I really messed up this time, was moving the top piece of the pod and accidently pulled out the ribbon connector for the joystick, bent a few of the pins trying to put it back on...
danmcclain2019
Postby rustyjames » 15 Jun 2019, 13:18
You should be able to find one of those controllers on eBay. Or try Liberty Mobility in Warrick RI.
rustyjames
Postby woodygb » 15 Jun 2019, 13:39
danmcclain2019 wrote:Think I really messed up this time, was moving the top piece of the pod and accidently pulled out the ribbon connector for the joystick, bent a few of the pins trying to put it back on...
The actual joystick is a fairly universal item in the Penny & Giles range...
Postby woodygb » 15 Jun 2019, 13:47
Indeed ...AND the Vsi's board actually has a pin hole marked ON/OFF and another marked GND ..just connect the momentary switch between the 2.
Users browsing this forum: hank, salixfire, snaker, woodygb and 52 guests
