R-Net main controller model #
Postby Irving » 21 Aug 2019, 17:09
I recently had an email from a colleague asking about R-Net controller part numbers as he wanted to upgrade a relative's chair. It got me thinking that I've not seen a comprehensive list posted anywhere (I could be wrong).
So here goes my (not necessarily definitive) attempt...
We all know (I think) the PM120 (120amp) module is the one to go for. The generic PGDT part # for this is D50903.xx
However, a quick trawl through a few hundred (OK, so I was bored) on eBay also throws up a few other variants in the same case shape:
D50946.yy, where (so far) yy is 11 through 15. These all seem to be Permobil specific versions. Visually they appear to be similar but the Inhibit2 and On-board Charger sockets (the small ones to the RH end) appear to be blanked off. I wonder about the firmware.
D51254.01 claims to be a Meyra specific one and, more interestingly, suggests it's able to go to 220A (or rather has 220 in the little box where others have 80, 90 or 120). Not sure I believe that, but who knows? Again visually similar and the RH connectors are blanked off. Sold for 65€ on eBay earlier this year, but only the one listing ever.
It is generally thought that the .xx sub-identifier for the generic D50903 is the brand of chair it's intended for. That may or may not be true, but various numbers have been associated with multiple brands; sadly there's a lot of mis-information on eBay due to sellers copying each others adverts. Here is a list I've compiled (feel free to copy and add) :
  • .01 - .08 Nothing found
  • .09 - Handicare (Puma 40)
  • .10 - Quickie (Jive)
  • .11 - Scout Mobility
  • .12 - Quickie (QM710)
  • .13 - AMYSystems Alltrack
  • .14 - Permobil
Re: R-Net main controller model #
Postby Burgerman » 21 Aug 2019, 17:36
The blanked off connectors are just rubber bungs.
Same on ISM and other modules.
All the permobil, sunrise 120A (see white lable for 120) are the same. They all have different part numbers because they they are plug and play, No programming.
Postby Irving » 21 Aug 2019, 18:16
Burgerman wrote:The blanked off connectors are just rubber bungs.
OK on the bungs.
I should have been clearer about the phrase "intended for" and said "originally intended for" as I accept they are interchangeable parts (as far as we know).
But if they are all the same why give them different part #? That makes no sense for PGDT to have to hold, track and manage all that inventory. There has to be some meaning in that suffix, even if it's of no relevance to us.
Also, just to be clear, are you saying that the D50903 and D50946 parts are equally interchangeable?
Postby Burgerman » 21 Aug 2019, 18:25
I am saying that when a user has a power module fitted to x chair, thats the part number in the parts book. Because a "tech" doesent know enough about programming, and doesent usually posess an OEM level programmer. So they are programmed with default settings for every specific chair and sit on the shelf waiting to be plugged and played. That way we dont get wrong brake votages, wrong compensation, wrong seating parameters, or fit a front drive chair with a PM programmed for a rear drive..
But YOU or I can take any of them and configure from scratch. Or clone the chair it will be used on if its a replacement. So as long as its marked 120 you are good to go.
And there are many 80 amp and 90A (built in seating - cheapness less capable) always available. But with a third less torque. OK if you are in a mid drive 4 or 6mph, and not too heavy. Otherwise run away.
Postby Burgerman » 21 Aug 2019, 18:32
The 120A ones are tank steer, 2x 120A channels (one per motor).
The 210A ones are odd. Its a scooter controller, modded at the factory so that they can use both channels as a single 220A output to drive a scooter style chair. No steering on that 210A output. And then they use another output similar to a seating actuator to STEER the powered casters via a servo. Theres some very weird mixing going on there. Thats not one thats any good for us. They behave a little oddly, not like a tank steered chair.
Postby Irving » 21 Aug 2019, 18:48
Burgerman wrote:I am saying that when a user has a power module fitted to x chair, thats the part number in the parts book. Because a "tech" doesent know enough about programming, and doesent usually posess an OEM level programmer. So they are programmed with default settings for every specific chair and sit on the shelf waiting to be plugged and played. That way we dont get wrong brake votages, wrong compensation, wrong seating parameters, or fit a front drive chair with a PM programmed for a rear drive..
OK, I got that. I wonder if pgdt actually hold them pre-programmed or program to order?
I recently came across the same situation with my AEG washing machine, the main controller died. So the repair guy came round, fitted new board. No joy. After some head-scratching he went back to his van and brought in another board. Worked! He explained that the boards are all generic across a range of AEG, Bosch, etc machines and are programmed to order in the office but when they'd programmed the boards for his work rota that morning theyd put the wrong board in the box marked with my job #. Fortunately he only had 2 that day.
There's a warning there though. If you buy a 'generic' controller on eBay and fit it, there's a possibility you could do a lot of damage to yourself or your surroundings if you don't program it straight away.
Postby Burgerman » 21 Aug 2019, 18:56
Correct!
I have seen a chair with a replaced controller via a dealer. It was the right PM but had been programmed for the 4 pole version of the chair (40mOhm) instead of the 2 pole version. That should have been 80 or 90. So it refused to turn. Or accelerate. Or slow down properly. And was like driving with 4 flat tyres.
Had that been the oppsite way around, then it could have took of in any direction and be totally out of control and broke someones legs. Dealer probably thought that they all looked the same. So...
Postby ex-Gooserider » 27 Aug 2019, 04:55
Same sort of thing applies to the older Pilot + controllers - lots of different part numbers, but only a handful of different Amp ratings, which can be seen on the P&G label in the little box.....
The problem I saw on some of the eBay listings was that not all the controllers had a P&G label on them - some it was just missing / torn off / illegible, others it was covered up by a manufacturer's label w/ a manufacturer's part number on it, and there was no real way to tell what Amp rating it was....
(unless really cheap I'd pass on those...)
Users browsing this forum: Gnomatic, Google [Bot] and 21 guests
